I am using a Jetson Nano and followed the Object Detection in 10 lines of code of Python. My camera feed is upside down, and I cannot simply rotate it physically due to a mounting constraint.
I was wondering if there is a command or something I can edit in the .h or .cpp file to flip the camera feed by 180? The topics in the past seem out dated as the solutions are not applicable to the current .cpp files where it says to change flip_method = 2 or etc. The flip_method is nowhere to be found in the .cpp or .h file
