There is a block of code in gstCamera.cpp, i’m using it in jetson:
#if NV_TENSORRT_MAJOR > 4
// on newer JetPack’s, it’s common for CSI camera to need flipped
// so here we reverse FLIP_NONE with FLIP_ROTATE_180
if( mOptions.flipMethod == videoOptions::FLIP_NONE )
mOptions.flipMethod = videoOptions::FLIP_ROTATE_180;
else if( mOptions.flipMethod == videoOptions::FLIP_ROTATE_180 )
mOptions.flipMethod = videoOptions::FLIP_NONE;
ss << “nvarguscamerasrc sensor-id=” << mOptions.resource.port << " saturation=1 aeantibanding=0 awblock=true ee-mode=1 ee-strength=1 exposuretimerange=‘34000 4166000’ ! video/x-raw(memory:NVMM), width=(int)" << GetWidth() << “, height=(int)” << GetHeight() << “, framerate=” << (int)mOptions.frameRate << “/1, format=(string)NV12 ! nvvidconv left=640 bottom=100 top=100 flip-method=” << mOptions.flipMethod << " ! “;
// orginal was: ss << “nvarguscamerasrc sensor-id=” << mOptions.resource.port << " ! video/x-raw(memory:NVMM), width=(int)” << GetWidth() << “, height=(int)” << GetHeight() << “, framerate=” << (int)mOptions.frameRate << “/1, format=(string)NV12 ! nvvidconv flip-method=” << mOptions.flipMethod << " ! ";
#else
Is this flipping only required to turn image to be right - so the right side is on right and left on left or is there any other reason? I think it consumes GPU…
