How to know which yolo variant has used in sample
Software Version
DRIVE OS 6.0.10.0
[1] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1] other
Host Machine Version
other
Issue Description
Hi team, there is a sample named “sample object detector tracker”. I went through the code. I could see yolo has been used but I want to know which version or variant of yolo has been used in object detection.
TensorRT is used as an accelerator???
Dear @akshay.tupkar,
Updated the topic as per Announcement from NVIDIA: Guidelines to create a new topic . Please follow the same for future topics.
Please find the model at /usr/local/driveworks/data/samples/detector/yolo.onnx
Yes. The sample uses TensorRT optimzed model.
Dear @SivaRamaKrishnaNV
Yolo is a dnn based model and tensorRT is optimising the yolo model. So yolo is responsible for detecting objects or tensorRT is detection objects. It is creating a confusion
TensorRT is an SDK used to optimize your DNN model to improve inference performance. The optimization process involves fusion of DNN layers and picking up optimal GPU kernels for the layers on that HW. This allows you get good inference speed up when using TRT model compared to ONNX DNN model in your application.
Note that, DW allows the models generated using DriveWorks SDK Reference: TensorRT Optimizer Tool .
Thanks for sharing this information @SivaRamaKrishnaNV
Is there any tool to view the yolo.onnx file to see its content, I could open it using vi editor but it is not fully understandable. I want to know the yolo varient used
You could check with tools like netron.
Thanks dear @SivaRamaKrishnaNV
