Testing sample_object_detector_tracker on 6.0.8 fails
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi ,
I am using the sample example for dnn in 6.0.8 sample_object_detector_tracker. Can nvidia say what is the tensorrt model they used for testing this ? I see there is YoloV3 incorporated into, so the default tensorRT_model.bin is not working as expected. can Nvidia point me to the right model used to test yolo with this sample.
Regards,
Sistla.
Thank you for reaching out. To better assist you, could you please provide more details about the issue you’re experiencing with the default ‘tensorRT_model.bin’ in the ‘sample_object_detector_tracker’ example? Specifically, if you could explain what isn’t working as expected and any error messages or observations you’ve encountered, it would help us pinpoint the issue more accurately.
Dear @0xdeadbeef ,
Could you check /usr/local/driveworks/data/samples/detector for model. May I know the error details? Are you running the sample on host or target?
Dear @0xdeadbeef,
I have verified the sample and notice no issue on target. I coped the input video file and model file to target from docker and ran using below command.
File paths on docker
input video: /usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264
Model : :/usr/local/driveworks/data/samples/detector/ampere-integrated/tensorRT_model.bin
Json file : /usr/local/driveworks/data/samples/detector/ampere-integrated/tensorRT_model.bin.json (It is used by sample internally)
Command
./sample_object_detector_tracker --video=/home/nvidia/video_0.h264 --tensorRT_model=/home/nvidia/tensorRT_model.bin
