Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
[√] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[√] other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
When i use “Basic Object Detector and Tracker Sample”, i find that the yellow bounding box in the window is very small, so i can’t do Object Detector and Tracker.
I use the Entron F008A120RM0AES, and the command is following:
./sample_object_detector_tracker --input-type=camera --camera-type=F008A120RM0A --camera-group=c --camera-index=1
The log is following:
nvidia@tegra-ubuntu:/usr/local/driveworks/samples/bin$ sudo ./sample_object_detector_tracker --input-type=camera --camera-type=F008A120RM0A --camera-group=c --camera-index=1
ProgramArguments: Missing argument ‘dwTracePath’ requested
[22-10-2022 12:16:29] Platform: Detected Drive Orin P3710
[22-10-2022 12:16:29] TimeSource: monotonic epoch time offset is 1666437705065534
[22-10-2022 12:16:29] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[22-10-2022 12:16:29] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[22-10-2022 12:16:29] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[22-10-2022 12:16:29] PTP Time is available from Eth Driver
[22-10-2022 12:16:29] Adding variable DW_Base:DW_Version
[22-10-2022 12:16:29] Addded variable DW_Base:DW_Version
[22-10-2022 12:16:29] Platform: number of GPU devices detected 1
[22-10-2022 12:16:29] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_04_12_05, Arch: ga10b
[22-10-2022 12:16:29] Platform: currently selected GPU device integrated ID 0
[22-10-2022 12:16:29] CUDLAEngine:getDLACountandCheck: CUDLA version is = 1002001
[22-10-2022 12:16:29] CUDLAEngine:getDLACountandCheck: Number of DLA devices = 2
[22-10-2022 12:16:29] ========== DLA Device 0 Attributes ==========
[22-10-2022 12:16:29] UVA supported = 0
[22-10-2022 12:16:29] Device version = 1
[22-10-2022 12:16:29] Device 0 Check PASSED
[22-10-2022 12:16:29] ========== DLA Device 1 Attributes ==========
[22-10-2022 12:16:29] Device 1 Check PASSED
[22-10-2022 12:16:29] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[22-10-2022 12:16:29] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.8/samples/bin/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.8/samples/bin/data/resources.pak’
[22-10-2022 12:16:29] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks/data
[22-10-2022 12:16:29] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks/data/resources.pak’
[22-10-2022 12:16:29] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.8/data
[22-10-2022 12:16:29] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.8/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.8/data/resources.pak’
[22-10-2022 12:16:29] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks/lib/libdw_base.so.5.8
[22-10-2022 12:16:29] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.8/targets/aarch64-Linux/lib/libdw_base.so.5.8
[22-10-2022 12:16:29] SDK: No resources(.pak) mounted, some modules will not function properly
[22-10-2022 12:16:29] SDK: Create NvMediaDevice
[22-10-2022 12:16:29] SDK: use EGL display as provided
[22-10-2022 12:16:29] Initialize DriveWorks SDK v5.8.82
[22-10-2022 12:16:29] Release build with GNU 9.3.0 from buildbrain-branch-0-g33d6f4a1440 against Drive PDK v6.0.5.0
[22-10-2022 12:16:29] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[22-10-2022 12:16:29] TimeSensor: initialized with no UTC time reference.
[22-10-2022 12:16:29] EndpointNVPPS: started on /dev/nvpps0
[22-10-2022 12:16:29] Initialize DriveWorks VisualizationSDK v5.8.82
[22-10-2022 12:16:29] Initialize DriveWorksGL SDK v5.8.82
[22-10-2022 12:16:29] SensorFactory::createSensor() → camera.gmsl, camera-type=F008A120RM0A,camera-group=c,slave=0,serialize=false,camera-count=4,camera-mask=0010
[22-10-2022 12:16:29] CameraGMSLSelector: cameraCount is a deprecated parameter, please remove as it has no more effect
[22-10-2022 12:16:29] CameraGMSLSelector: camera-mask is a deprecated parameter, please remove from your rig and replace with parameter link
[22-10-2022 12:16:29] CameraGMSLSelector: camera-mask 0010 was automatically translated to link 1. Note that it will be overridden by parameter link if present
[22-10-2022 12:16:29] CameraGMSLSelector: missing siblingIndex to be able to map to new camera.gmsl parameter called link, assuming link 0
[22-10-2022 12:16:29] CameraGMSLSelector: note the name doesn’t correspond to the old supported cameras, DW will pass the name as is to the SIPL library. Please consider replacing camera-type with camera-name
[22-10-2022 12:16:29] CameraGMSLSelector: creating CameraClient from remapped old gmsl parameters to camera-type=F008A120RM0A,camera-group=c,slave=0,serialize=false,camera-count=4,camera-mask=0010,camera-name=F008A120RM0A,interface=csi-ef,link=1
[22-10-2022 12:16:29] CameraGMSLSelector: missing ‘output-format=processed/yuv’ in the sensor parameters, frames might be captured with bad sensor settings(AE/AWB) and reprocess may result image quality issues
[22-10-2022 12:16:29] CameraBase: pool size set to 8
[22-10-2022 12:16:29] SensorFactory::createSensor() → camera.gmsl.master,
[22-10-2022 12:16:29] CameraMaster::parseDevBlock Getting device info list.
[22-10-2022 12:16:29] devBlock: 0 Slave = 0 Interface = csi-ef Camera_name = F008A120RM0A Link = 1
[22-10-2022 12:16:29] Camera Match Name: F008A120RM0A Description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295 linkIndex: 4294967295 serInfo.Name: MAX9295
[22-10-2022 12:16:29] Client, Setting up information for camera ID 0
[22-10-2022 12:16:29] Client, successfully found info for camera ID 0 bound to id 0
[22-10-2022 12:16:29] ImageStreamer(NvMedia → CUDA)
[22-10-2022 12:16:29] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/F008A120RM0A.nito
SimpleCamera: Camera image: 3848x2168
Camera image with 3848x2168 at 30 FPS
[22-10-2022 12:16:29] FileHeader: file header created with development build (patch = -1), assumingcompatibility
[22-10-2022 12:16:30] [MemUsageChange] Init CUDA: CPU +263, GPU +0, now: CPU 453, GPU 5765 (MiB)
[22-10-2022 12:16:30] Loaded engine size: 23 MiB
[22-10-2022 12:16:30] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[22-10-2022 12:16:30] Deserialization required 15391 microseconds.
[22-10-2022 12:16:30] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +23, now: CPU 0, GPU 23 (MiB)
[22-10-2022 12:16:30] Total per-runner device persistent memory is 719360
[22-10-2022 12:16:30] Total per-runner host persistent memory is 122368
[22-10-2022 12:16:30] Allocated activation device memory of size 69010432
[22-10-2022 12:16:30] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +67, now: CPU 0, GPU 90 (MiB)
[22-10-2022 12:16:30] DNN: Missing or incompatible parameter in metadata (tonemapType). Parameter is set to default value. See dwDataConditioner for default values.
[22-10-2022 12:16:30] DNN: Missing or incompatible parameter in metadata (channelIdx). Parameter is set to default value. See dwDataConditioner for default values.
[22-10-2022 12:16:30] DataConditioner: Scale transformation has been configured with 1.000000.
[22-10-2022 12:16:30] DataConditioner: Mean value subtract transformation has been configured with {0.0000, 0.0000, 0.0000}.
[22-10-2022 12:16:30] DataConditioner: Standard deviation has been configured with {1.0000, 1.0000, 1.0000}.
[22-10-2022 12:16:30] 1
[22-10-2022 12:16:30] SIPLMaster::SIPLMaster: Setting up master camera
Could not create NVCCP shared memory nvccpmutex
[22-10-2022 12:16:30] Platform:
[22-10-2022 12:16:30] Platform Config:
[22-10-2022 12:16:30] Description:
[22-10-2022 12:16:30] Number of device blocks: 1
[22-10-2022 12:16:30] Device Block : 0
[22-10-2022 12:16:30] csiPort: 8
[22-10-2022 12:16:30] i2cDevice: 2
[22-10-2022 12:16:30] Deserializer Name: MAX96712
[22-10-2022 12:16:30] Deserializer Description: Maxim 96712 Aggregator
[22-10-2022 12:16:30] Deserializer i2cAddress: 41
[22-10-2022 12:16:30] Simulator Mode: 0
[22-10-2022 12:16:30] Passive Mode: 0
[22-10-2022 12:16:30] Phy Mode: 0
[22-10-2022 12:16:30] Number of camera modules: 1
[22-10-2022 12:16:30] CameraModule index: 1
[22-10-2022 12:16:30] Name :F008A120RM0A
[22-10-2022 12:16:30] Description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295
[22-10-2022 12:16:30] Serializer name: MAX9295
[22-10-2022 12:16:30] Serializer description: Maxim 9295 Serializer
[22-10-2022 12:16:30] Serializer i2cAdress: 98
[22-10-2022 12:16:30] EEPROM name: N24C64
[22-10-2022 12:16:30] EEPROM i2cAddress: 84
[22-10-2022 12:16:30] EEPROM description: N24C64 EEPROM
[22-10-2022 12:16:30] Sensor ID: 0
[22-10-2022 12:16:30] Sensor name: AR0820
[22-10-2022 12:16:30] Sensor description: OnSemi AR0820 Sensor
[22-10-2022 12:16:30] Sensor i2cAddress: 16
[22-10-2022 12:16:30] Sensor isTPGEnabled: 0
[22-10-2022 12:16:30] Sensor isTriggerMode: 1
[22-10-2022 12:16:30] cfa: 35
[22-10-2022 12:16:30] embeddedTopLines: 6
[22-10-2022 12:16:30] embeddedBottomLines: 0
[22-10-2022 12:16:30] inputFormat: 8
[22-10-2022 12:16:30] height: 2168
[22-10-2022 12:16:30] width: 3848
[22-10-2022 12:16:30] fps: 30.000000
[22-10-2022 12:16:30] Embedded Data: 1
[22-10-2022 12:16:30] CameraMaster available outputs: 3
[22-10-2022 12:16:30] CameraClient: setting pipeline config for camera ID 0
[22-10-2022 12:16:30] CameraMaster: master initiation
MAX96712: Revision 5 detected
MAX96712 Link 1: PHY optimization was enabled
MAX9295: Revision 8 detected!
Sensor AR0820 GRBG Rev 2.1 detected!
[22-10-2022 12:16:30] CameraMaster: Bootstrap NvSIPL and ClientPipelines complete
[22-10-2022 12:16:30] CameraClient::readEEPROMInfo:
[22-10-2022 12:16:30] mmIntrinsicModelID: 27
[22-10-2022 12:16:30] mmIntrinsicCoeff[0]: -0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[1]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[2]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[3]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[4]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[5]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[6]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[7]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[8]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[9]: 1.892143e+11
[22-10-2022 12:16:30] mmIntrinsicCoeff[10]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[11]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[12]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[13]: 0.000000
[22-10-2022 12:16:30] mmIntrinsicCoeff[14]: 0.000170
[22-10-2022 12:16:30] mmIntrinsicCoeff[15]: 8.000000
[22-10-2022 12:16:30] mmIntrinsicMeasuredFlagID: 237
[22-10-2022 12:16:30] fwVersionMajor: 0
[22-10-2022 12:16:30] fwVersionMinor: 0
[22-10-2022 12:16:30] fwVersionPatch: 0
[22-10-2022 12:16:30] CameraMaster: starting…
[22-10-2022 12:16:30] CameraClient: allocating image pool for ICP
[22-10-2022 12:16:30] Allocating NvSci group
[22-10-2022 12:16:30] CameraClient: allocate image pool for 0
[22-10-2022 12:16:30] Allocating NvSci ISP0 images
[22-10-2022 12:16:30] CameraClient: format not specified. Using h264 in Codec Header.
[22-10-2022 12:16:31] SIPLClient: Acquisition started
[22-10-2022 12:16:31] DNN: run infer internal batchsize 1 is not needed after 8.4.10.4.
[22-10-2022 12:16:31] CameraClient: Notification received from pipeline index:0 of type: NOTIF_WARN_ICP_FRAME_DROP
[22-10-2022 12:16:31] SIPLDeviceBlockNotificationHandler: Queue timeout
