I tried the similar testing on the driveos6.0.8(Driveworks 5.14) and the result is even worse it took about 28~29 ms to compress an 8MP image.
I modified sample_camera to make * * dwSerializerParams. onData * * work,also measured the timestamp difference between the moment right before calling the function dwSensorSerializer_serializeCameraFrameAsync and the moment once get into our callback function.
Do I need to set other parameters to improve compression performance?
Camera: AR0820 8MP
Log:
Warning: SamplesDataPath::getBasePathFor(): ‘DATA_ROOT’ not found in search paths [/home/nvidia/samples_bin/data | /home/nvidia/samples_bin.runfiles/av/data | /home/nvidia/samples_bin/sample_camera.runfiles/av/data | /home/nvidia/samples_bin/data | /home/nvidia/data | /home/data]
ProgramArguments: Missing argument ‘dwTracePath’ requested
WindowEGL: find EGL devices
WindowEGL: found 1 EGL devices
WindowEGL: init EGL with GLES3 context
WindowEGL: bind OpenGLES3 API
WindowEGL: offscreen mode → use EGL PBuffer surface 1280x800
WindowEGL: create EGL context
WindowEGL: assign EGL context to current thread
[25-03-2024 10:46:12] Platform: Detected Drive Orin P3710
[25-03-2024 10:46:12] Adding variable DW_Base:DW_Version
[25-03-2024 10:46:12] Added variable DW_Base:DW_Version
[25-03-2024 10:46:12] Platform: number of GPU devices detected 1
[25-03-2024 10:46:12] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_06_10_03, Arch: ga10b
[25-03-2024 10:46:12] Platform: currently selected GPU device integrated ID 0
[25-03-2024 10:46:12] CUDLAEngine:getDLACount: CUDLA version is = 1004000
[25-03-2024 10:46:12] CUDLAEngine:getDLACount: Number of DLA devices = 2
[25-03-2024 10:46:12] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[25-03-2024 10:46:12] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/home/nvidia/samples_bin/data’: VirtualFileSystem: Failed to mount ‘/home/nvidia/samples_bin/data/resources.pak’
[25-03-2024 10:46:12] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.14/data
[25-03-2024 10:46:12] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.14/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.14/data/resources.pak’
[25-03-2024 10:46:12] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.14/targets/aarch64-Linux/lib/libdw_base.so.5.14
[25-03-2024 10:46:12] SDK: No resources(.pak) mounted, some modules will not function properly
[25-03-2024 10:46:12] SDK: use EGL display as provided
[25-03-2024 10:46:12] [25-03-2024 10:46:12] Initialize DriveWorks SDK v5.14.74
[25-03-2024 10:46:12] [25-03-2024 10:46:12] Release build with GNU 9.3.0 from buildbrain-branch-0-g30b7ba5bb0c against Drive PDK v6.0.8.0
[25-03-2024 10:46:12] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[25-03-2024 10:46:12] Found driver: time.nvpps
[25-03-2024 10:46:12] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
Error: Permission denied
[25-03-2024 10:46:12] fromFile: Loading rig file: ./rig_ar0820.json
[25-03-2024 10:46:12] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[25-03-2024 10:46:12] No valid data file found for camera:sample0 in parameter string: camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216 (using configuration folder ./)
onInitialize: creating camera.gmsl with params: camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216
[25-03-2024 10:46:12] SensorFactory::createSensor() → camera.gmsl, camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216
[25-03-2024 10:46:12] Found driver: camera.gmsl
[25-03-2024 10:46:12] CameraBase: pool size set to 8
[25-03-2024 10:46:12] SensorFactory::createSensor() → camera.gmsl.master,
[25-03-2024 10:46:12] Found driver: camera.gmsl.master
[25-03-2024 10:46:13] CameraMaster::parseDevBlock Getting device info list.
[25-03-2024 10:46:13] devBlock: 0 Slave = 0 Interface = csi-ef Camera_name = F008A120RM0AV2 Link = 0 GroupInit = 0
[25-03-2024 10:46:13] Camera Match Name: F008A120RM0AV2 Description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295 linkIndex: 4294967295 serInfo.Name: MAX9295
[25-03-2024 10:46:13] Authentication is disabled for camera F008A120RM0AV2
[25-03-2024 10:46:13] Not an EEPROM supported camera F008A120RM0AV2
[25-03-2024 10:46:13] Client, Setting up information for camera ID 0
[25-03-2024 10:46:13] Client, successfully found info for camera ID 0 bound to id 0
[25-03-2024 10:46:13] ImageStreamer(NvMedia → CUDA)
[25-03-2024 10:46:13] CameraClient: using NITO found at /usr/share/camera/F008A120RM0AV2.nito
[25-03-2024 10:46:13] CameraClient: CVARS not registered for camera: F008A120RM0AV2
[25-03-2024 10:46:13] SyncDriver: GPU device available, enabling CUDA sync
[25-03-2024 10:46:13] SyncDriver: enableCUDAPresync, object successfully created
[25-03-2024 10:46:13] SIPLMaster::SIPLMaster: Setting up master camera
[25-03-2024 10:46:13] Platform:
[25-03-2024 10:46:13] Platform Config:
[25-03-2024 10:46:13] Description:
[25-03-2024 10:46:13] Number of device blocks: 1
[25-03-2024 10:46:13] Device Block : 0
[25-03-2024 10:46:13] csiPort: 8
[25-03-2024 10:46:13] i2cDevice: 2
[25-03-2024 10:46:13] cphyRate_0: 2000000
[25-03-2024 10:46:13] cphyRate_1: 2000000
[25-03-2024 10:46:13] Deserializer Name: MAX96712
[25-03-2024 10:46:13] Deserializer Description: Maxim 96712 Aggregator
[25-03-2024 10:46:13] Deserializer i2cAddress: 41
[25-03-2024 10:46:13] Passive Mode: 0
[25-03-2024 10:46:13] Phy Mode: 1
[25-03-2024 10:46:13] Number of camera modules: 1
[25-03-2024 10:46:13] CameraModule index: 0
[25-03-2024 10:46:13] Name :F008A120RM0AV2
[25-03-2024 10:46:13] Description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295
[25-03-2024 10:46:13] Serializer name: MAX9295
[25-03-2024 10:46:13] Serializer description: Maxim 9295 Serializer
[25-03-2024 10:46:13] Serializer i2cAdress: 98
[25-03-2024 10:46:13] EEPROM name: N24C64
[25-03-2024 10:46:13] EEPROM i2cAddress: 84
[25-03-2024 10:46:13] EEPROM description: N24C64 EEPROM
[25-03-2024 10:46:13] Sensor ID: 0
[25-03-2024 10:46:13] Sensor name: AR0820
[25-03-2024 10:46:13] Sensor description: OnSemi AR0820 Sensor
[25-03-2024 10:46:13] Sensor isTPGEnabled: 0
[25-03-2024 10:46:13] Sensor i2cAddress: 16
[25-03-2024 10:46:13] Sensor isTriggerMode: 1
[25-03-2024 10:46:13] cfa: 35
[25-03-2024 10:46:13] embeddedTopLines: 2
[25-03-2024 10:46:13] embeddedBottomLines: 4
[25-03-2024 10:46:13] inputFormat: 8
[25-03-2024 10:46:13] height: 2168
[25-03-2024 10:46:13] width: 3848
[25-03-2024 10:46:13] fps: 30.000000
[25-03-2024 10:46:13] Embedded Data: 0
[25-03-2024 10:46:13] CameraMaster available outputs: 1
[25-03-2024 10:46:13] CameraClient: setting pipeline config for camera ID 0
[25-03-2024 10:46:13] CameraClient, SIPLNotifier created
[25-03-2024 10:46:13] CameraMaster: master initiation
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX9295: Revision 8 detected!
Sensor AR0820 GRBG Rev 2.1 detected!
[25-03-2024 10:46:13] CameraMaster: Bootstrap NvSIPL and ClientPipelines complete
[25-03-2024 10:46:13] CameraClient::readEEPROMInfo:
[25-03-2024 10:46:13] mmIntrinsicModelID: 27
[25-03-2024 10:46:13] mmIntrinsicCoeff[0]: -0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[1]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[2]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[3]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[4]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[5]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[6]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[7]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[8]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[9]: 1.892143e+11
[25-03-2024 10:46:13] mmIntrinsicCoeff[10]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[11]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[12]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[13]: 0.000000
[25-03-2024 10:46:13] mmIntrinsicCoeff[14]: 0.000170
[25-03-2024 10:46:13] mmIntrinsicCoeff[15]: 8.000000
[25-03-2024 10:46:13] mmIntrinsicMeasuredFlagID: 237
[25-03-2024 10:46:13] fwVersionMajor: 0
[25-03-2024 10:46:13] fwVersionMinor: 0
[25-03-2024 10:46:13] fwVersionPatch: 0
[25-03-2024 10:46:13] CameraClient: format not specified. Using mp4 in Codec Header.
[25-03-2024 10:46:13] [25-03-2024 10:46:13] SAL: bootstrap complete
[25-03-2024 10:46:13] Initialize DriveWorks VisualizationSDK v5.14.74
[25-03-2024 10:46:13] Initialize DriveWorksGL SDK v5.14.74
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
----- format(h264=0) = 0
---- 111 the old ser parameters : camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216,type=disk,file=./ar0820_out.h264
,used param:camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,format=h264,framerate=30,bitrate=32000000,type=user
[25-03-2024 10:46:13] CameraClient: camera params: camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,format=h264,framerate=30,bitrate=32000000,type=user
[25-03-2024 10:46:13] CameraClient: h264 and h265 video format encoding is deprecated. Please switch to a different format.
[25-03-2024 10:46:13] CameraClient::createSerializer: Serializer created for ISP Pipeline: 0
[25-03-2024 10:46:13] EncoderNvMedia: Setting encode on instance 0
[25-03-2024 10:46:13] EncoderNvMedia: Header Information not available for h264/h265 , Default Header Data
@@@@@ initializeSerializer 0! status=0
Main: Starting master.
[25-03-2024 10:46:13] CameraMaster: starting…
[25-03-2024 10:46:13] CameraClient: allocating image pool for ICP
[25-03-2024 10:46:13] Allocating NvSci group
[25-03-2024 10:46:13] CameraClient: allocate image pool for 0
[25-03-2024 10:46:13] Allocating NvSci ISP0 images
[25-03-2024 10:46:13] SIPLClient: Acquisition started
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363573839.713
###> After serializerOnDataFunc, datasize: 17084,endTimePoint: 1711363573868.837**,elpsedTime: 29.123**
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363573917.001
###> After serializerOnDataFunc, datasize: 250688,endTimePoint: 1711363573946.645,elpsedTime: 29.644
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363573962.166
###> After serializerOnDataFunc, datasize: 273652,endTimePoint: 1711363573991.538,elpsedTime: 29.372
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363574004.539
###> After serializerOnDataFunc, datasize: 312080,endTimePoint: 1711363574033.797,elpsedTime: 29.258
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363574046.739
###> After serializerOnDataFunc, datasize: 313103,endTimePoint: 1711363574075.836,elpsedTime: 29.097
===> before_calling_dwSensorSerializer_serializeCameraFrameAsync timepoint:1711363574088.769
[25-03-2024 10:46:14] SIPLNotifier: Notification received from pipeline index:0 of type: NOTIF_WARN_ICP_FRAME_DROP
[25-03-2024 10:46:15] SIPLDeviceBlockNotificationHandler: Queue timeout
Timing results:
Thread main:
-onProcess CPU: 4us, std= 5 | GPU: 4us, std= 1 | samples=45
-onRender CPU: 41246us, std=19502 | GPU: 41271us, std=19497 | samples=45
[25-03-2024 10:46:15] Sensor Health Signal for camera[0] camera.gmsl, camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216
timestamp: 1711363575773184 sourceID: 1
Sensor notifications:
[25-03-2024 10:46:15] Sensor statistics for: camera[0] camera.gmsl, camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216
[25-03-2024 10:46:15] Statistics for DW_SENSOR_STATE_DELTA_HOST_AND_HOST_TIME
Events: 94
Errors: 0
CRC Errors: 0
Drops: 10
minDelta: 33292.0000 us
maxDelta: 66701.0000 us
meanDelta: 40152.2969us
Standard deviation: 13443.1006
[25-03-2024 10:46:15] Statistics for DW_SENSOR_STATE_DELTA_SENSOR_AND_SENSOR_TIME
Events: 94
Errors: 0
CRC Errors: 0
Drops: 10
minDelta: 0.0000 us
maxDelta: 0.0000 us
meanDelta: 0.0000us
Standard deviation: 0.0000
[25-03-2024 10:46:15] Statistics for DW_SENSOR_STATE_DELTA_HOST_AND_SENSOR_TIME
Events: 94
Errors: 0
CRC Errors: 0
Drops: 10
minDelta: -2.8130e+14 us
maxDelta: -2.8130e+14 us
meanDelta: -2.8130e+14us
[25-03-2024 10:46:15] Statistics for DW_SENSOR_STATE_DELTA_CURRENT_AND_HOST_TIME
Events: 94
Errors: 0
CRC Errors: 0
Drops: 10
minDelta: 0.0000 us
maxDelta: 0.0000 us
meanDelta: 0.0000us
[25-03-2024 10:46:15] Statistics for DW_SENSOR_STATE_DELTA_READ_AND_RETURN_FRAME_TIME
Events: 94
Errors: 0
CRC Errors: 0
Drops: 10
minDelta: 40992.0000 us
maxDelta: 77024.0000 us
meanDelta: 42166.0391us
Standard deviation: 5291.0229
Serializer statistics for sensor: camera:sample0
Statistics for DW_SERIALIZER_STAT_DISK_WRITE_TIME
minDelta: 0 us
maxDelta: 0 us
meanDelta: 0.000 us
standardDeviationDelta: 0.000
Statistics for DW_SERIALIZER_STAT_ENCODE_TIME
minDelta: 28288 us
maxDelta: 29440 us
meanDelta: 28534.043 us
standardDeviationDelta: 269.748
Statistics for DW_SERIALIZER_STAT_STAGE1_TIME
minDelta: 128 us
maxDelta: 672 us
meanDelta: 263.111 us
standardDeviationDelta: 162.734
Statistics for DW_SERIALIZER_STAT_STAGE2_TIME
minDelta: 128 us
maxDelta: 480 us
meanDelta: 277.333 us
standardDeviationDelta: 141.348
Statistics for DW_SERIALIZER_STAT_STAGE3_TIME
minDelta: 27712 us
maxDelta: 28384 us
meanDelta: 27993.602 us
standardDeviationDelta: 147.586
[25-03-2024 10:46:15] Serializer: drained data to
[25-03-2024 10:46:15] SIPLClient: Total number of frames with FrameAccumulator = 4
[25-03-2024 10:46:15] Buffers(Processed) should be released before calling DeInit() on sipl camera
[25-03-2024 10:46:16] SIPLDeviceBlockNotificationHandler: Queue timeout
[25-03-2024 10:46:16] SIPLClient: ImageQueue timeout
[25-03-2024 10:46:16] SIPLNotifier: Event notification queue timeout
[25-03-2024 10:46:16] Deinit master camera
[25-03-2024 10:46:16] SIPLNotifier: Event notification queue shutdown
[25-03-2024 10:46:16] CameraClient: Stopping client
[25-03-2024 10:46:16] Releasing camera master
[25-03-2024 10:46:17] SIPLDeviceBlockNotificationHandler: Queue timeout
[25-03-2024 10:46:17] Driveworks VisualizationSDK released
[25-03-2024 10:46:17] [25-03-2024 10:46:17] Releasing Driveworks SDK Context
[25-03-2024 10:46:17] DriveworksGL SDK released
The rig.json:
“rig”: {
“sensors”: [
“name”: “camera:sample0”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [
0.0,
0.0,
0.0
“t”: [
1.8621,
-0.1939,
1.3165
“parameter”: “camera-name=F008A120RM0AV2,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,async-record=0,file-buffer-size=16777216”,
“properties”: {
“COMMENT”: “Nominals estimated for car27 / VIN=275155 (http://nvbugs/2869761/1)”,
“Model”: “ftheta”,
“bw-poly”: “0.000000000000000 5.35356812179089e-4 4.99266072928606e-10 4.27370422037554e-12 -6.68245573791717e-16”,
“cx”: “1927.764404”,
“cy”: “1096.686646”,
“height”: “2168”,
“width”: “3848”
“protocol”: “camera.gmsl”
“vehicle”: {
“valid”: false
“version”: 6
