Driveworks9.0 failed to enable Object Detector Tracker functions
Dear Sir,
I enter the command to enable “sample_object_detector_tracker” sample functions, but it is terminated by “The engine plan file is generated on an incompatible device, expecting compute 7.2got compute 7.5, please rebuild”. I am not sure if there are any machine limitations for Drive AGX. Does it need any settings for the sample functions?
nvidia@tegra-ubuntu:/usr/local/driveworks$ /usr/local/driveworks/bin/sample_object_detector_tracker --video=/usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264 --tensorRT_model=/usr/local/driveworks/data/samples/detector/turing/tensorRT_model.bin
[26-08-2019 15:18:07] Platform: Detected DDPX - Tegra A
[26-08-2019 15:18:07] Initialize DriveWorks SDK v2.0.2081
[26-08-2019 15:18:07] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[26-08-2019 15:18:07] TimeSource: monotonic epoch time offset is 1566779368878891
[26-08-2019 15:18:07] PTP Time is available from NVPPS Driver
[26-08-2019 15:18:07] Platform: number of GPU devices detected 1
[26-08-2019 15:18:07] Platform: currently selected GPU device integrated ID 0
[26-08-2019 15:18:07] SDK: Resource failed to mount from ‘…/./data/’: VirtualFileSystem: Failed to mount ‘…/./data/[.pak]’
[26-08-2019 15:18:07] SDK: Resources mounted from /usr/local/driveworks-2.0/data/
[26-08-2019 15:18:07] SDK: Create NvMediaDevice
[26-08-2019 15:18:07] SDK: use EGL display as provided
[26-08-2019 15:18:07] Initialize DriveWorks VisualizationSDK v2.0.2081
[26-08-2019 15:18:07] Initialize DriveWorksGL SDK v2.0.2081
[26-08-2019 15:18:07] SensorFactory::createSensor() → camera.virtual, camera-group=a,camera-index=0,camera-type=ar0231-rccb-bae-sf3324,input-type=video,offscreen=0,profiling=1,slave=0,tensorRT_model=/usr/local/driveworks/data/samples/detector/turing/tensorRT_model.bin,video=/usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264
[26-08-2019 15:18:07] CameraVirtualNvMedia: no seek table found at /usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264.seek, seeking is not available.
SimpleCamera: Camera image: 1280x800
Camera image with 1280x800 at 30 FPS
[26-08-2019 15:18:07] StreamConsumerGL: successfully initialized
[26-08-2019 15:18:07] StreamProducerCUDA: successfully initialized
[26-08-2019 15:18:07] The engine plan file is generated on an incompatible device, expecting compute 7.2got compute 7.5, please rebuild.
update the module name as below, it works…
volta-integrated
nvidia@tegra-ubuntu:/usr/local/driveworks/data/samples/detector$ /home/nvidia/peter/ad_sample --video=/usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264 --tensorRT_model=/usr/local/driveworks/data/samples/detector/volta-integrated/tensorRT_model.bin
Dear melinda.hung,
It looks like you have DRIVE AGX Xavier platform which does not have discrete GPU.
Compute capability 7.2 indicates Volta based GPU. So you should use tensorRT models generated for volta GPUs.
