nvidia@tegra-ubuntu:~/gokul$ ./tensorRT_optimization --modelType=onnx --onnxFile=blaze_face_short_range.onnx --out=test_folder/test.bin
[27-02-2024 07:33:52] WARNING: ExplicitBatch is enabled by default for ONNX models.
[27-02-2024 07:33:52] WARNING: --batchSize is ignored for explicit batch ONNX models for TRT versions after 6.2.0.3
Use model.batch[BATCH_SIZE].onnx (eg. model.batch8.onnx with ONNX batch size 8) with accompanying batch_sizes in configuration.json instead.
[27-02-2024 07:34:05] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
[27-02-2024 07:34:05] DNNGenerator: Initializing TensorRT generation on model blaze_face_short_range.onnx.
[27-02-2024 07:34:05] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[27-02-2024 07:34:05] DNNGenerator: Input “input”: 1x3x128x128
[27-02-2024 07:34:05] DNNGenerator: Output “regressors”: 1x896x16
[27-02-2024 07:34:05] DNNGenerator: Output “classificators”: 1x896x1
[27-02-2024 07:34:06] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:07] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:08] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:09] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:10] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:11] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:12] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:13] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:14] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:15] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:16] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:17] Caught cuda error during timing, format rejected.
[27-02-2024 07:34:17] GPU error during getBestTactic: conv2d + activation : no kernel image is available for execution on the device
[27-02-2024 07:34:17] 1: [convBaseRunner.cpp::execute::271] Error Code 1: Cask (Cask convolution execution)
[27-02-2024 07:34:17] 1: [checkMacros.cpp::catchCudaError::202] Error Code 1: Cuda Runtime (no kernel image is available for execution on the device)
[27-02-2024 07:34:18] 2: [builder.cpp::buildSerializedNetwork::751] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
[27-02-2024 07:34:18] Releasing Driveworks SDK Context
Error: DW_INTERNAL_ERROR: DNNGenerator: Network build and serialization failed.
