Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Pegasus DevKit (E3550)
other
SDK Manager Version
[*] 1.7.1.8928
other
Host Machine Version
[*] native Ubuntu 18.04
other
Ran sample application using pre-recorded video data using custom TensorRT model converted through Onnx to TRT with the help of this notebook TensorRT/4. Using PyTorch through ONNX.ipynb at main · NVIDIA/TensorRT · GitHub but we are getting the below error.
Command we used for conversion inside the jupyter notebook is:
# convert the ONNX model to a TRT engine using trtexec
if USE_FP16:
!/usr/src/tensorrt/bin/trtexec --onnx=resnet50_pytorch.onnx --saveEngine=resnet_engine_pytorch.trt --explicitBatch --inputIOFormats=fp16:chw --outputIOFormats=fp16:chw --fp16
else:
Please advise the right way for converting models to TensorRT engine compatible for Driveworks apps.
Nvidia_Drive@tegra-ubuntu:/usr/local/driveworks-3.5/bin$ ./sample_dnn_tensor --input-type=video --video=/usr/local/driveworks-3.5/tools/capture/camera_front_center_120fov.h264 --tensorRT_model=/home/Nvidia_Drive/Documents/resnet_engine_pytorch.trt
[04-03-2022 16:43:23] Platform: Detected DDPX - Tegra A
[04-03-2022 16:43:23] TimeSource: monotonic epoch time offset is 1646133716873257
[04-03-2022 16:43:23] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[04-03-2022 16:43:23] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[04-03-2022 16:43:23] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[04-03-2022 16:43:23] Platform: number of GPU devices detected 2
[04-03-2022 16:43:23] Platform: currently selected GPU device discrete ID 0
[04-03-2022 16:43:23] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[04-03-2022 16:43:23] SDK: No resources(.pak) mounted, some modules will not function properly
[04-03-2022 16:43:23] SDK: Create NvMediaDevice
[04-03-2022 16:43:23] SDK: Create NvMedia2D
[04-03-2022 16:43:23] SDK: use EGL display as provided
[04-03-2022 16:43:24] TimeSource: monotonic epoch time offset is 1646133716873257
[04-03-2022 16:43:24] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[04-03-2022 16:43:24] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[04-03-2022 16:43:24] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[04-03-2022 16:43:24] Initialize DriveWorks SDK v3.5.75
[04-03-2022 16:43:24] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[04-03-2022 16:43:24] Initialize DriveWorks VisualizationSDK v3.5.75
[04-03-2022 16:43:24] Initialize DriveWorksGL SDK v3.5.75
[04-03-2022 16:43:24] SensorFactory::createSensor() -> camera.virtual, camera-group=a,camera-index=0,camera-type=ar0231-rccb-bae-sf3324,input-type=video,offscreen=0,profiling=1,slave=0,tensorRT_model=/home/Nvidia_Drive/Documents/resnet_engine_pytorch.trt,video=/usr/local/driveworks-3.5/tools/capture/camera_front_center_120fov.h264
[04-03-2022 16:43:24] CameraVirtual: defaulting to non SIPL
[04-03-2022 16:43:24] CameraBase: pool size set to 8
[04-03-2022 16:43:24] CameraVirtualNvMedia: no seek table found at /usr/local/driveworks-3.5/tools/capture/camera_front_center_120fov.h264.seek, seeking is not available.
SimpleCamera: Camera image: 1920x1208
Camera image with 1920x1208 at 30 FPS
[04-03-2022 16:43:24] StreamConsumerGL: successfully initialized
[04-03-2022 16:43:24] StreamProducerCUDA: successfully initialized
[04-03-2022 16:43:24] DNN: TensorRT model file has wrong magic number. Please ensure that the model has been created by TensorRT_optimization tool in DriveWorks. The model might be incompatible.
[04-03-2022 16:43:25] INVALID_CONFIG: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[04-03-2022 16:43:25] INVALID_CONFIG: Deserialize the cuda engine failed.
[04-03-2022 16:43:25] Driveworks exception thrown: DW_INTERNAL_ERROR: DNN: Unable to load model.
terminate called after throwing an instance of 'std::runtime_error'
what(): [2022-03-04 16:43:25] DW Error DW_INTERNAL_ERROR executing DW function:
dwDNN_initializeTensorRTFromFile(&m_dnn, tensorRTModel.c_str(), nullptr, DW_PROCESSOR_TYPE_GPU, m_sdk)
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/dnn/sample_dnn_tensor/main.cpp:234
Aborted (core dumped)
