Conversion of onnx to tensorrt
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hi team, How can we convert onnx model to tensorrt engine? Is there any tool to do so?
Please help!
Dear @akshay.tupkar ,
Please use /usr/src/tensort/bin/trtexec for model conversion and benchmarking. You can also use TensorRT APIe directly. Please see trtexec source code if you want to use APIs.
If you plan to use DW, please check DriveWorks SDK Reference: TensorRT Optimizer Tool
dear @SivaRamaKrishnaNV thanks a lot
what is the difference between trtexec and tensorRT optiization tool? Do they work same?
TensorRT optimization tool uses TRT APIs internally and generates model which is compatible with DW DNN APIs.
Dear @SivaRamaKrishnaNV
The source code for tensorRT optimizer has not been provided?
The source code is not available in public release.
