Hi team,
I am working on DRIVE Orin with DRIVE OS 6.0.6. I went through driveworks documention and I came across a sample named sample_object_detector_tracker. For your reference I am attaching its link. After executing a sample on drive orin, I am not getting the output as shown in the documentation. I am attaching both the scenarios, an expected output and the output which I am getting.
Dear @SivaRamaKrishnaNV
I have DRIVE OS 6.0.6. Will I have to upgrade Drive OS 6.0.6 to Drive OS 6.0.8.1? I s there any issue with source code itself or model?
Dear @SivaRamaKrishnaNV Switching to DRIVE OS latest release, version of Driveworks will also be changed? Will that same sample work in Drive OS 6.0.8.1?
Since I am new to this platform, Could you please guide me with how to upgrade the system to latest release? What all are the required steps?
Again my doubt is, If i switch to Drive OS 6.0.8.1, whatever the softwares that i have installed such as opencv, etc will be removed after upgrading the system?
Dear @akshay.tupkar,
You can use sdkmanager to flash the target. But we recommend to use docker container to avoid issues related to host environment. We expect the steps provided in the flash using docker to work. Please file a new topic in case of any issues.
