Are the perception samples available for Driveworks 4.0?
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I need a pedestrian & car detector. In Driveworks 3.5 I could use DriveNet but this is not available in DriveWorks 4.0.
Is there a tensorrt model which I could download and use it via the dnn tensor api (sample_dnn_tensor) ?
Or an onnx model which could be converted to tensorrt 6.5 ?
Please refer to the diagram on NVIDIA DRIVE OS | NVIDIA Developer. The Perception module is part of DRIVE AV, situated above DriveWorks, and it’s exclusively available in DRIVE Software.
Thx. Can you give advise of a drivenet like model which I could use with the dnn tensor api ? It is for an experimental setup, which will never go on the road.
YOLO could be a suitable choice.
Hi, I tried to use yolo v3.
I get following error when optimizing the onnx model to trt.
tensorRT_optimization (TensorRT) 6.5.00
This is a DNN generating tool based on TensorRT.
[26-04-2024 11:16:42] WARNING: ExplicitBatch is enabled by default for ONNX models.
[26-04-2024 11:16:43] DNNGenerator: Initializing TensorRT generation on model /home/nvidia/yolov3.onnx.
Input filename:   /home/nvidia/yolov3.onnx
ONNX IR version:  0.0.6
Opset version:    11
Producer name:    NVIDIA TensorRT sample
Producer version:
Domain:
Model version:    0
Doc string:
[26-04-2024 11:16:44] DNNGenerator: Input "000_net": 3x608x608
[26-04-2024 11:16:44] DNNGenerator: Output "082_convolutional": 255x19x19
[26-04-2024 11:16:44] DNNGenerator: Output "094_convolutional": 255x38x38
[26-04-2024 11:16:44] DNNGenerator: Output "106_convolutional": 255x76x76
[26-04-2024 11:16:44] DNNGenerator: Building Engine...
[26-04-2024 11:18:32] ../rtSafe/cudaDevice.cpp (190) - Cuda Error in allocateImpl: 2 (out of memory)
[26-04-2024 11:18:32] ../rtSafe/resources.cpp (36) - OutOfMemory Error in gieCudaMalloc: 0 (GPU Memory allocation fails!)
[26-04-2024 11:18:32] FAILED_ALLOCATION: std::exception
I’m running everything on the target.
Generated the onnx from the /usr/src/tensorrt/samples/python/yolov3_onnx folder.
this was how I ran the optimization (on the target):
/usr/local/driveworks-4.0/tools/dnn/tensorRT_optimization --modelType=onnx --onnxFile=/home/nvidia/yolov3.onnx --out=/home/nvidia/yolov3.bin
What I understood was that we need to use the yolov3 on the target because of the ROI that is injected in one of the layers, right ? So any other tensorrt sdk version won’t work, right ?
After some googling I found that the batch and subdivision is set to training in the yolov3.cfg. I set it to testing and don’t get the out of memory problem anymore.
However, after the interpretation of the output, I can’t get object detections.
The inference also runs very slow.
Attached you can find the source code.
This is how I run it:
main.zip (10.1 KB)
yolov3.bin.zip (410 Bytes)
yolov3.zip (856 Bytes)
./sample_dnn_tensor --input-type=video --video=/usr/local/driveworks/data/samples/sfm/triangulation/video_0.h264 --tensorRT_model=yolov3.bin
Please check if these topics can help resolve your issue:
They were my source of inspiration. I’ve managed to get the network running, but the output has weird values. Could you have a look in my code (main.zip, see above)) if everything is setup properly ?
Dear @erwin.rademakers ,
Could you double check the preprocessing step needed for YOLO v3. I see input data is scaled by 1/255 in /usr/src/tensorrt/samples/python/yolov3_onnx/data_processing.py . Make sure the data fed into yolov3 network is same in both TensorRT and DW sample for comparison.
Thank you, that part I was missing!
