How to list the sources in streamux
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• Issue Type( questions, new requirements, bugs) question
how can i list the names of sources (pad names)connected to streammux (debug purpose, I would like to check if the source is removed )?
I extended the runtime_src_add_delete.py to add source using runtime through API hit, the ID is the camera ID from DB (eg, 1000, 1025, 1036). I use this ID to create the bin name
bin_name="source-bin-%02d" % ID
unlike the example runtime_src_add_delete.py the bin_name doesn’t starts from 0, it can be any integer. Is this approach OK? or should i have to start naming the bin_name from 0 in terms of computational efficiency.
please refer to GstElement
it is ok, the name can be custom.
