How to measure PGIE latency?
the title is pretty self-explanatory, I need to have a reliable measure of the time it takes to a batch to pass thru a PGIE element;
which is the recommended strategy?
thanks in advance,
f
Cuda has the bandwidth test sample to test host to device and device to host bandwidth. /usr/local/cuda/samples/1_Utilities/bandwidthTest
thanks for replying;
maybe I didn’t express myself clearly;
I need a reliable measure of the inference time;
the h2d and d2h memcopy are not part of this analysis;
I found this API searching within your documentation
https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/DeepStream_Development_Guide/baggage/group__ee__nvlatency__group.html
I use the function
num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
inside a probe attached to the primary sink pad, where latency info is allocated like this
NvDsFrameLatencyInfo *latency_info = (NvDsFrameLatencyInfo *) malloc(batch_size * sizeof(NvDsFrameLatencyInfo));
the problem is that when the probe is triggered and the function above is executed I get a segmentation fault; am I missing any step? I could not find any code sample of how to use this API
thanks again,
f
Can you refer to
sources/apps/sample_apps/deepstream-app/deepstream_app.c → latency_measurement_buf_prob()
Ensure that Jetson clocks are set high. Run these commands to set Jetson clocks high.
$ sudo nvpmodel -m --for MAX perf and power mode is 0
$ sudo jetson_clocks
https://docs.nvidia.com/metropolis/deepstream/plugin-manual/index.html#page/DeepStream_Plugin_Manual%2Fdeepstream_plugin_troubleshooting.html → The DeepStream application is running slowly
To enable frame latency measurement, run this command on the console:
$ export NVDS_ENABLE_LATENCY_MEASUREMENT=1
•To enable latency for all plugins, run this command on the console:
$ export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1
Using deepstream app, for latency measurement user should use RTSP or USB live sources and not file based
