I tried to replace the Linux_for_tegra/bootloader/BOOTAA64.efi and Linux_for_tegra/bootloader/uefi_jetson.bin from R35.3.1 to R35.2.1.Then flash the whole board.It still doesn’t work.
Related topics
| Orin nx boot order changer after restore system | 14 | 1675 | May 5, 2023 | |
| 64G AGX Orin boot Order Getting Reset (JetPack 5.1.1 - L4T r35.3.1) | 12 | 1156 | December 13, 2023 | |
| Boot order change after restore from orin A to orin B | 6 | 728 | January 30, 2024 | |
| Boot order change after massflash | 10 | 1014 | August 9, 2023 | |
| Newly flashed Orin NX 16G model and NVME SSD, blocked at"Starting HTTP Boot over IPV4" | 4 | 161 | July 29, 2024 | |
| Boot Issue After Image Recovery on NVMe SSD Orin Nano Custom Board Jetpack6.1 | 10 | 302 | April 11, 2025 | |
| Boot Order Issue on Orin Nano | 4 | 444 | September 5, 2024 | |
| Exception problem using orin nx | 13 | 546 | February 29, 2024 | |
| Initrd flash boot order | 31 | 3095 | October 25, 2022 | |
| Orin flashed to external USB drive. But doesn't boot from it | 15 | 1022 | August 23, 2023 |
