Newly flashed Orin NX 16G model and NVME SSD, blocked at"Starting HTTP Boot over IPV4"
Hi
I flashed Orin NX & NVME SSD successfully (Orin NX 16G & Jetpack5.1.2) by command “sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02+p3767-0000 internal”. when start, it blocked at “Starting HTTP Boot over IPV4”.
I try to change boot order and I cannot find SSD boot option.
ESC to enter UEFI setup, select reset and then it can boot kernel normally, what’s the problem with it, how to fix it? thank you!
Hi zangyichang,
Are you using the devkit or custom board for Orin NX?
It seems UEFI can not recognize your NVMe SSD during boot up.
Please share the full flash log for further check.
It is running on custom board. We are switching new SSD vendor, it running OK with old SSD model. Attached flash log, please help, thank you!
flash_1-1_0_20240725-140201.tar.gz (6.6 KB)
Do you mean that the issue is specific to your current NVMe SSD?
If so, could you reproduce the similar issue on the devkit with this NVMe SSD?
It looks good in your flash log.
