System I have is an Orin NX (16GB). I flashed the system to an external USB drive (128GB). The flashing process was quite smooth, using the following command
Afterwards, the system booted from the external USB. Then I went through all the GUIs on the license agreement, setting up applications, setting up Chrome, etc. See for example,
System rebooted after setting up. But, it ignored the USB drive and tried to boot from internet without success. Eventually, it ended up in an UEFI shell. See the photos.
have you checked if you are able to enter the UEFI boot menu to change the boot order?
Or try removing the Ethernet cable in case it’s plugged in to the device.
Thank you for your reply. The Ethernet cable was not connected. Yes, I entered the UEFI boot menu, but the external USB was not on the list, only UEFI HTTP, UEFI PXE and UEFI Shell entries.
couple more question here.
Is the carrier board a custom one, or the Xavier NX DevKit(p3509-a02+p3767-0000)?
What L4T version is in use? Have you tried with a different USB drive?
Flashing to the NVME was successful and the OS boots normally. However, flashing to an external USB results in failure as I mentioned in the first post. Different USB driver yields the same result, no boot. I don’t have access to UART, neither can I connect to with TTL-USB.
