I have a Jetson Orin NX 16 GB configured on a custom carrier board. I am trying to flash the board from a 64 GB USB drive with l4t_initrd_flash.sh script. I have updated “num_sectors” in flash_l4t_external.xml with the number of sectors (120164352) and “ROOTFSSIZE” in p3767.conf.common to 51GiB. Within the BSP directory on my host PC, I run the following command to flash the board when it’s in recovery mode:
Thanks ~0326
Could you execute below commands and share results with us?
