Could I flash Orin NX 16G module with L4T 36.2 on the Orin nano carrier board to an USB storage?
Yes, you can use SDK manager to flash your Orin NX module+Orin Nano carrier board, be sure to choice the correct storage device option.
I failed,and my configuration is
1.Ubuntu 20.04/x86_64/i7
2.kernel: 5.15.0-107-generic
3.SDK Manager : 2.1.0.11682_x86_64
4.Jetpack 6.0(REV.2)/ R36 (release), REVISION: 3.0
Attached are the gui procedures and logs, please help, thanks.
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_NX_modules_2024-06-17_09-15-29.zip (429.6 KB)
0_gui_steps.zip (2.7 MB)
1_log.zip (22.0 KB)
09:26:39.510 - Info: Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.0gy8KO8akr. You can access the target’s terminal through “sshpass -p root ssh root@fc00:1:1:0::2”
Disable the firewall setting on your host PC. There is NFS server setup needed during flash process.
I use ufw command to disable, then I flash by sdk-manager.
I still get fail, I use some commands to query the status of nfs server,it seems not running. I also use “sshpass -p root ssh root@fc00:1:1:0::1” to connect to host pc, but can’t connect.
log_nfs.txt (6.3 KB)
1.How to disable firewall ?
root@JamesCheng-ub20:~# sudo ufw disable
Firewall stopped and disabled on system startup
root@JamesCheng-ub20:~# sudo ufw status
Status: inactive
2.How to check the nfs server is running correctly ?
Is the same result on your side by flashing R36.3.0 ?
Yes, but I can use the same environment to flash L4T 35.4.1, and device can work correctly.
Still can’t success by using L4T 36.3.0
Is there any update?
Just try a quick way… find another host PC to test first.
