The expansion backplane needs to include a PCIe switch with support for nontransparent bridging. This feature is required to connect the multiple root complexes together. Also it is advised to find PCIe switch with DMA engine for efficient transfer offload.
For example, a switch from this table ([url]Products) that has both 2 NT port and DMA engines. You’ll need to fiddle with the switch’s EEPROM to assign 2 of the Jetson’s to NT ports and the third Jetson as the upstream port.
I’m curious to try it, although I have doubts that my hacked-together method with the Jetsons would work (and even if it did, it probably would only link at gen1). Instead we’ve been collaborating on a project to create a custom PCB to verify the architecture. One of the positives is you get access to all x4 gen2 lanes instead of the Jetson’s x1. So up to 2000 MB/s between TK1’s.
