Hi, I’m new to this forum. I’m learning PhysX, cause i want to implement physics module to my engine. Now i am interested in converting rotations. I am new to quaternions and i would like to know how to properly change from PxQuat to uVector3F (my 3d vector class) and uVector3F to PxQuat.
Here is my actual code:
physx::PxQuat uVector3F::toQuaternion() const
uVector3F angles = this->toRadians();
physx::PxReal cos_x = cosf(angles.x);
physx::PxReal cos_y = cosf(angles.y);
physx::PxReal cos_z = cosf(angles.z);
physx::PxReal sin_x = sinf(angles.x);
physx::PxReal sin_y = sinf(angles.y);
physx::PxReal sin_z = sinf(angles.z);
physx::PxQuat quat = physx::PxQuat();
quat.w = cos_x*cos_y*cos_z + sin_x*sin_y*sin_z;
quat.x = sin_x*cos_y*cos_z - cos_x*sin_y*sin_z;
quat.y = cos_x*sin_y*cos_z + sin_x*cos_y*sin_z;
quat.z = cos_x*cos_y*sin_z - sin_x*sin_y*cos_z;
return quat;
uVector3F uVector3F::quaternionToEuler(const physx::PxQuat &quat)
float sqw = quat.w*quat.w;
float sqx = quat.x*quat.x;
float sqy = quat.y*quat.y;
float sqz = quat.z*quat.z;
uVector3F euler;
euler.x = atan2f(2.f * (quat.z*quat.y + quat.x*quat.w), 1 - 2 * (sqx + sqy));
euler.y = asinf(-2.f * (quat.x*quat.z - quat.y*quat.w));
euler.z = atan2f(2.f * (quat.x*quat.y + quat.z*quat.w), 1 - 2 * (sqy + sqz));
return euler;
The first function uVector3F::toQuaternion i found in this forum, so i think it’s working. I think the problem is in second function.
The problem:
I put simple barrel about 40 units above other (super-sized in x,z cause i use this like temporary ground :] ) barrel. I’ve set dynamic barrel rotation to (X,Y,Z) (90, 0, 0) and the barrel is not rotated :( Also, when it ALWAYS returns to 0,0,0 rotation even if it lays on side.
