I want to change uboot logo .
h@ubuntu:~/nvidia-uefi/edk2-nvidia/Platform/NVIDIA/Jetson [main] (main)$ python -m pip install --upgrade edk2-pytool-extensions
Defaulting to user installation because normal site-packages is not writeable
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Requirement already satisfied: edk2-pytool-extensions in /home/h/.local/lib/python3.9/site-packages (0.24.1)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)’: /simple/edk2-pytool-extensions/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)’: /simple/edk2-pytool-extensions/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)’: /simple/edk2-pytool-extensions/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)’: /simple/edk2-pytool-extensions/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)’: /simple/edk2-pytool-extensions/
Could not fetch URL https://pypi.org/simple/edk2-pytool-extensions/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘pypi.org’, port=443): Max retries exceeded with url: /simple/edk2-pytool-extensions/ (Caused by SSLError(“Can’t connect to HTTPS URL because the SSL module is not available.”)) - skipping
Requirement already satisfied: edk2-pytool-library>=0.16.1 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (0.18.2)
Requirement already satisfied: pyyaml>=6.0.0 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (6.0.1)
Requirement already satisfied: pefile>=2023.2.7 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (2023.2.7)
Requirement already satisfied: semantic-version>=2.10.0 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (2.10.0)
Requirement already satisfied: GitPython>=3.1.30 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (3.1.40)
Requirement already satisfied: openpyxl>=3.1.2 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (3.1.2)
Requirement already satisfied: XlsxWriter>=3.0.9 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-extensions) (3.1.9)
Requirement already satisfied: pyasn1>=0.4.8 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (0.5.1)
Requirement already satisfied: pyasn1-modules>=0.2.8 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (0.3.0)
Requirement already satisfied: cryptography>=39.0.1 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (41.0.7)
Requirement already satisfied: joblib>=1.3.2 in /home/h/.local/lib/python3.9/site-packages (from edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (1.3.2)
Requirement already satisfied: gitdb<5,>=4.0.1 in /home/h/.local/lib/python3.9/site-packages (from GitPython>=3.1.30->edk2-pytool-extensions) (4.0.11)
Requirement already satisfied: et-xmlfile in /home/h/.local/lib/python3.9/site-packages (from openpyxl>=3.1.2->edk2-pytool-extensions) (1.1.0)
Requirement already satisfied: cffi>=1.12 in /home/h/.local/lib/python3.9/site-packages (from cryptography>=39.0.1->edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (1.16.0)
Requirement already satisfied: smmap<6,>=3.0.1 in /home/h/.local/lib/python3.9/site-packages (from gitdb<5,>=4.0.1->GitPython>=3.1.30->edk2-pytool-extensions) (5.0.1)
Requirement already satisfied: pycparser in /home/h/.local/lib/python3.9/site-packages (from cffi>=1.12->cryptography>=39.0.1->edk2-pytool-library>=0.16.1->edk2-pytool-extensions) (2.21)
h@ubuntu:~/nvidia-uefi/edk2-nvidia/Platform/NVIDIA/Jetson [main] (main)$ ./build.sh
nvidia: building from workspace rooted at: /home/h/nvidia-uefi
nvidia: found command: python3.
nvidia: found command: virtualenv.
nvidia: found command: mono.
nvidia: found command: aarch64-linux-gnu-gcc.
nvidia: found Python 3.9 or later.
nvidia: Activating Python virtual environment.
nvidia: Updating build environment (edk2-nvidia/Platform/NVIDIA/Jetson/PlatformBuild.py).
SECTION - Init Self Describing Environment
SECTION - Loading Plugins
SECTION - Start Invocable Tool
SECTION - Initial update of environment
Updating. Done
SECTION - Updated/Verified 2 dependencies
SECTION - Second pass update of environment
Updating. Done
SECTION - Summary
PROGRESS - Success
nvidia: Building basetools.
File “edk2/BaseTools/Edk2ToolsBuild.py”, line 15, in
from edk2toolext import edk2_logging
ModuleNotFoundError: No module named ‘edk2toolext’
how to slove?
