In jetson sdk 32.5,
I write a pcie driver running on an endpoint device. The code is like this:
in the driver thread:
while (true) {
dma_write(transfer);
static int dma_write(struct data_transfer *transfer)
int channel = 0;
u32 val = 0;
unsigned long now, timeout = msecs_to_jiffies(1000);
/* program registers */
/* Enable Write Engine */
dma_common_wr(ep->dma_base, DMA_WRITE_ENGINE_EN_OFF_ENABLE,
DMA_WRITE_ENGINE_EN_OFF);
/* Un Mask DONE and ABORT interrupts */
val = dma_common_rd(ep->dma_base, DMA_WRITE_INT_MASK_OFF);
val &= ~(1 << channel); /* DONE */
val &= ~(1 << ((channel) + 16)); /* ABORT */
dma_common_wr(ep->dma_base, val, DMA_WRITE_INT_MASK_OFF);
val = dma_channel_rd(ep->dma_base, channel, DMA_CH_CONTROL1_OFF_WRCH);
val = DMA_CH_CONTROL1_OFF_WRCH_LIE; //non linklist mode
dma_channel_wr(ep->dma_base, channel, val, DMA_CH_CONTROL1_OFF_WRCH);
//non linklist mode
dma_channel_wr(ep->dma_base, channel, transfer->request_tlen,
DMA_TRANSFER_SIZE_OFF_WRCH);
(transfer->src_iova_addr & 0xFFFFFFFF),
DMA_SAR_LOW_OFF_WRCH);
((transfer->src_iova_addr >> 32) & 0xFFFFFFFF),
DMA_SAR_HIGH_OFF_WRCH);
(transfer->dst_iova_addr & 0xFFFFFFFF),
DMA_DAR_LOW_OFF_WRCH);
((transfer->dst_iova_addr >> 32) & 0xFFFFFFFF),
DMA_DAR_HIGH_OFF_WRCH);
/* ring the door bell with channel number */
dma_common_wr8(ep->dma_base, channel, DMA_WRITE_DOORBELL_OFF);
now = jiffies;
while (true) {
val = dma_common_rd(ep->dma_base, DMA_WRITE_INT_STATUS_OFF);
if (BIT(channel) & val) {
dma_common_wr(ep->dma_base, BIT(channel), DMA_WRITE_INT_CLEAR_OFF);
break;
if (time_after(jiffies, now + timeout)) {
printk("DMA write timed out & poll end\n");
DMA_WRITE_DOORBELL_OFF_WR_STOP | channel,
return -ETIMEDOUT;
return 0;
My question is that I want to use interrupt by request_irq method instead of polling DMA_WRITE_INT_STATUS_OFF register. The cpu utilization reaches 99% when polling DMA_WRITE_INT_STATUS_OFF register. What I should do to relize it?
