My Nano 2G environment is as follows.
I compiled and ran yolov5_tensorrt
, the yolov5s.engine
file is generated. Running the yolov5s program for image detection and video detection is normal. When I use yolov5s.engine
for deepstream-test5-app, the following errors occur. Please guide me how to deal with this problem.
$ /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test5/deepstream-test5-app -tc config.txt
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
0:00:02.791838930 11903 0x557aa88690 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: [TRT]: 1: [pluginV2Runner.cpp::load::290] Error Code 1: Serialization (Serialization assertion creator failed.Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::50] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: Deserialize engine failed from file: /home/jetson/JetsonX/yolov5s.engine
0:00:08.335878414 11903 0x557aa88690 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/home/jetson/JetsonX/yolov5s.engine failed
0:00:08.338798607 11903 0x557aa88690 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/home/jetson/JetsonX/yolov5s.engine failed, try rebuild
0:00:08.338859023 11903 0x557aa88690 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:08.901675892 11903 0x557aa88690 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:08.902872812 11903 0x557aa88690 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:08.902925676 11903 0x557aa88690 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:08.903049217 11903 0x557aa88690 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:08.903076665 11903 0x557aa88690 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /home/jetson/JetsonX/config_infer_primary_nano.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:1455>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
