• Hardware Platform (dGPU)
• DeepStream Version 5.0
How to run two pipelines correctly? one pipeline works on video, and the second pipeline turns on by event and works on pictures. At the moment I am getting an error when changing the state of the second pipeline to play.
pipeline for images:
pipeline for video:
gdb error when load primary detector engine of second pipeline:
0:00:48.991474828 15955 0x555555e72ad0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 4]: deserialized trt engine from :/media/daliel/hdd/from_main/deepstream/python/apps/deepstream-app-3/ocr_ctc_17.onnx_b4_gpu0_fp32.engine
INFO: [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT Placeholder:0 3x133x133 min: 1x3x133x133 opt: 4x3x133x133 Max: 4x3x133x133
1 OUTPUT kFLOAT Reshape:0 880 min: 0 opt: 0 Max: 0
ERROR: [TRT]: INVALID_ARGUMENT: Cannot find binding of given name: Reshape
0:00:48.991540664 15955 0x555555e72ad0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1669> [UID = 4]: Could not find output layer 'Reshape' in engine
0:00:48.991547118 15955 0x555555e72ad0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 4]: Use deserialized engine model: /media/daliel/hdd/from_main/deepstream/python/apps/deepstream-app-3/ocr_ctc_17.onnx_b4_gpu0_fp32.engine
[New Thread 0x7fff27a15700 (LWP 19824)]
[New Thread 0x7fff617fe700 (LWP 19825)]
[New Thread 0x7fff60ffd700 (LWP 19826)]
0:00:48.993186706 15955 0x555555e72ad0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary3-nvinference-engine> [UID 4]: Load new model:numbers_sgie3_config.txt sucessfully
Thread 1 "deepstream-test" received signal SIGSEGV, Segmentation fault.
0x00007fffa577aac0 in ?? () from /usr/lib/x86_64-linux-gnu/libnvinfer.so.7
same code:
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
pipeline = gst_pipeline_new ("dstest3-pipeline");
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
//GstElement *source_bin = create_source_bin (i, uri.c_str());
GstElement *source_bin = create_source_bin (i, uri);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
if (!pgie) {
g_printerr ("Failed to create primary inference pipeline 1 element. Exiting.\n");
return -1;
// Use tracker
nvtracker = gst_element_factory_make ("nvtracker", "tracker");
//use secondary infer for classification
sgie1 = gst_element_factory_make("nvinfer", "secondary1-nvinference-engine");
if (!sgie1) {
g_printerr ("Failed to create secondary inference pipeline 1 element. Exiting.\n");
return -1;
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
if (save_result){
nvvidconv2 = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter1");
if (!nvvidconv2) {
g_printerr ("Failed to create nvvideo-converter2 element. Exiting.\n");
return -1;
caps_filter = gst_element_factory_make ("capsfilter", NULL);
if (!caps_filter) {
g_printerr ("Failed to create capsfilter element. Exiting.\n");
return -1;
GstCaps *caps = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "RGBA", NULL);
GstCapsFeatures *feature = gst_caps_features_new (GST_CAPS_FEATURES_NVMM, NULL);
gst_caps_set_features (caps, 0, feature);
g_object_set (G_OBJECT (caps_filter), "caps", caps, NULL);
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
#ifdef PLATFORM_TEGRA
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
if (!pgie || !nvtracker || !tiler || !nvvidconv || !nvosd || !sink) {
return -1;
g_object_set(G_OBJECT(nvosd), "nvbuf-memory-type", NVBUF_MEM_CUDA_UNIFIED, NULL);
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
#endif
g_printerr("setup pipeline\n");
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
"config-file-path", "DeepStream/config_infer_primary_yoloV4.txt", NULL);
g_object_set (G_OBJECT (pgie), "interval", 9, NULL);
g_object_set (G_OBJECT (sgie1),"config-file-path", "sgie_car_models.txt", NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
if (!set_tracker_properties(nvtracker, GPUID)) {
g_printerr ("Failed to set tracker properties. Exiting.\n");
return -1;
g_object_set (G_OBJECT (nvosd),
"nvbuf-memory-type", 3, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
//set GPU id
g_object_set (G_OBJECT (pgie), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (streammux), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (nvtracker), "gpu-id", GPUID, NULL);
g_object_get (G_OBJECT (sgie1), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (tiler), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (nvvidconv), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (nvosd), "gpu-id", GPUID, NULL);
g_printerr ("Create pipeline.\n");
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), pgie, nvtracker, sgie1, tiler, nvvidconv, caps_filter, nvosd, sink,
NULL);
//link queue process
if (!gst_element_link_many (streammux, pgie, nvtracker, sgie1, tiler, nvvidconv, caps_filter, nvosd, sink, NULL)) {
g_printerr ("Elements process could not be linked. Exiting.\n");
return -1;
tiler_src_pad = gst_element_get_static_pad (tiler, "sink");
if (!tiler_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "video-pipeline");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
g_print ("Running...\n");
g_main_loop_run (loop);
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
//gst_deinit();
//second pipe
//gst_init (&argc, &argv);
if (!pipeline){
g_printerr("Failed to create pipeline2. Exiting.\n");
return -1;
/* Create nvstreammux instance to form batches from one or more sources. */
streammux2 = gst_element_factory_make ("nvstreammux", "stream-muxer2");
if (!streammux2){
g_printerr("Failed to create streammux2 element. Exiting.\n");
return -1;
g_object_set(G_OBJECT (streammux2), "width", 416, NULL);
g_object_set(G_OBJECT (streammux2), "height", 416, NULL);
g_object_set(G_OBJECT (streammux2), "batch-size", 1, NULL);
g_object_set(G_OBJECT (streammux2), "batched-push-timeout", 4000000, NULL);
if(!gst_bin_add (GST_BIN (pipeline), streammux2)){
g_print("Failed add streammux2 to pipeline for image. Exiting.\n");
return -1;
//source image input
char images_uri[500];
char test[3] = "%d";
snprintf(images_uri, 500, "%s/images/%s.jpg", TMP_DIR, test);
GstElement *source_bin_image = create_source_image_bin (10, images_uri);
if (!source_bin_image) {
g_printerr ("Failed to create source bin image. Exiting.\n");
return -1;
if(!gst_bin_add (GST_BIN (pipeline), source_bin_image)){
g_print("Failed add source bin to pipeline for image. Exiting.\n");
return -1;
GstPad *sinkpad2, *srcpad2;
sinkpad2 = gst_element_get_request_pad (streammux2, "sink_0");
if (!sinkpad2) {
g_printerr ("Streammux2 request sink pad failed. Exiting.\n");
return -1;
srcpad2 = gst_element_get_static_pad (source_bin_image, "src");
if (!srcpad2) {
g_printerr ("Failed to get src pad of source bin image. Exiting.\n");
return -1;
if (gst_pad_link (srcpad2, sinkpad2) != GST_PAD_LINK_OK) {
return -1;
gst_object_unref (srcpad2);
gst_object_unref (sinkpad2);
fakesink = gst_element_factory_make("fakesink", "fakesink_image");
sgie2 = gst_element_factory_make("nvinfer", "primary2-nvinference-engine");
if (!sgie2) {
g_printerr ("Failed to create primary inference pipeline 2 element. Exiting.\n");
return -1;
sgie3 = gst_element_factory_make("nvinfer", "secondary3-nvinference-engine");
if (!sgie3) {
g_printerr ("Failed to create secondary inference pipeline 2 element. Exiting.\n");
return -1;
g_object_set (G_OBJECT (sgie2),"config-file-path", "DeepStream/config_infer_primary_yoloV4-tiny.txt", NULL);
g_object_get (G_OBJECT (sgie2), "batch-size", &spgie_batch_size, NULL);
if (spgie_batch_size != 1) {
g_printerr("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n", pgie_batch_size, num_sources);
g_object_set (G_OBJECT (sgie2), "batch-size", 1, NULL);
g_object_set (G_OBJECT (sgie3),"config-file-path", "numbers_sgie3_config.txt", NULL);
g_object_set (G_OBJECT (sgie2), "gpu-id", GPUID, NULL);
g_object_set (G_OBJECT (sgie3), "gpu-id", GPUID, NULL);
//pipeline2 for image decoding
gst_bin_add_many (GST_BIN (pipeline), sgie2, sgie3, fakesink, NULL);
if (!gst_element_link_many(streammux2, sgie2, sgie3, fakesink, NULL)){
g_printerr ("Elements pipeline2 could not be linked. Exiting.\n");
return -1;
sgie_sink_pad = gst_element_get_static_pad (sgie3, "sink");
if (!sgie_sink_pad)
g_print ("Unable to get sink pad\n");
else
gst_pad_add_probe (sgie_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
sgie_sink_pad_buffer_probe, NULL, NULL);
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "image-pipeline");
g_print("Starting pipeline image\n");
g_print("reading files %s\n", images_uri);
