If my use probe get queue,programme broken;
this pipline
* -> video-renderer */
if (!gst_element_link_many(streammux, queue1, pgie, queue2, nvdslogger, tiler,
queue3, nvvidconv, queue4, nvosd, queue5, sink, NULL))
g_printerr("Elements could not be linked. Exiting.\n");
return -1;
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
tiler_src_pad = gst_element_get_static_pad(queue4, "src");
if (!tiler_src_pad)
g_print("Unable to get src pad\n");
else
gst_pad_add_probe(tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
gst_object_unref(tiler_src_pad);
this probe
static GstPadProbeReturn
tiler_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *)info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
// NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
auto ret = write_frame(buf);
// g_print("add frame\n");
// exit(0);
return GST_PAD_PROBE_OK;
#define PLATFORM_TEGRA
int write_frame(GstBuffer *buf)
NvDsMetaList *l_user_meta = NULL;
// Get original raw data
GstMapInfo in_map_info;
char *src_data = NULL;
if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READ))
g_print("Error: Failed to map gst buffer\n");
gst_buffer_unmap(buf, &in_map_info);
NvBufSurface *surface = (NvBufSurface *)in_map_info.data;
l_frame = batch_meta->frame_meta_list;
if (l_frame)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
/* Validate user meta */
src_data = (char *)malloc(surface->surfaceList[frame_meta->batch_id].dataSize);
if (src_data == NULL)
g_print("Error: failed to malloc src_data \n");
#ifdef PLATFORM_TEGRA
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
NvBufSurfacePlaneParams *pParams = &surface->surfaceList[frame_meta->batch_id].planeParams;
unsigned int offset = 0;
for (unsigned int num_planes = 0; num_planes < pParams->num_planes; num_planes++)
if (num_planes > 0)
offset += pParams->height[num_planes - 1] * (pParams->bytesPerPix[num_planes - 1] * pParams->width[num_planes - 1]);
for (unsigned int h = 0; h < pParams->height[num_planes]; h++)
memcpy((void *)(src_data + offset + h * pParams->bytesPerPix[num_planes] * pParams->width[num_planes]),
(void *)((char *)surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[num_planes] + h * pParams->pitch[num_planes]),
pParams->bytesPerPix[num_planes] * pParams->width[num_planes]);
NvBufSurfaceSyncForDevice(surface, -1, -1);
NvBufSurfaceUnMap(surface, -1, -1);
#else
cudaMemcpy((void *)src_data,
(void *)surface->surfaceList[frame_meta->batch_id].dataPtr,
surface->surfaceList[frame_meta->batch_id].dataSize,
cudaMemcpyDeviceToHost);
#endif
gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width;
gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height;
gint frame_step = surface->surfaceList[frame_meta->batch_id].pitch;
cv::Mat frame = cv::Mat(frame_height, frame_width, CV_8UC4, src_data, frame_step);
// g_print("%d\n",frame.channels());
// g_print("%d\n",frame.rows);
// g_print("%d\n",frame.cols);
cv::Mat out_mat = cv::Mat(cv::Size(frame_width, frame_height), CV_8UC3);
cv::cvtColor(frame, out_mat, cv::COLOR_RGBA2BGR);
bgr_buffer.push(out_mat.clone());
// g_print("push a frame data\n");
// cv::imwrite("test.jpg", out_mat);
if (src_data != NULL)
free(src_data);
src_data = NULL;
