I would like to ask if there is an automatic way of saving the output of dnn samples provided by NVIDIA DRIVE. For example, i run DriveNet, SignNet etc and everything works fine. However, i need to save the output video with the bounding boxes, the annotations, etc in order to use it for my research.
Should i modify the .cpp file writing my own code in c++? Does NVIDIA Drive provide a library or a special module to export and save the processed videos?
Thank you in advance.
Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
NVIDIA DRIVE⢠Software 10.0 (Linux)
NVIDIA DRIVE⢠Software 9.0 (Linux)
other DRIVE OS version
other
I would like to thank you for your immediate response. I need to save the output for DNN transfer learning for my research. Thus, I need the output of a video that involves the annotations and the bounding boxes. Recording my screen will not provide this information.
I would be grateful, if you could inform me about the way I can save this output (For example, how i could modify the main.cpp code file).
Dear @ipapadea,
That is not possible with DW APIs. As we render frames and detections separately and overlay on frame. How about saving the detection for each frame, video seperately and use them later in your application ?
Dear @ipapadea,
Please check sample_camera_gmsl sample to know API usage to save video frame( it has write-file option). For saving detection output, check saving the detection output from object detector sample(the bounding box data structure rendered on frame needs to be saved) in seperate/single file for each frame and check loading these two in your application later. Please see if it works
