3080 ti
• DeepStream Version
6.1 triton
470.74
I want to use rtsp streaming as source for deepstream-test5 app
this is my config file setting
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=4
uri=rtsp://192.168.0.11:8554/test
num-sources=1
gpu-id=0
nvbuf-memory-type=0
but the following error occurred
ERROR from src_elem0: No supported stream was found. You might need to allow more transport protocols or may otherwise be missing the right GStreamer RTSP extension plugin.
Debug info: gstrtspsrc.c(7452): gst_rtspsrc_setup_streams_start (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0
** INFO: <reset_source_pipeline:1572>: Resetting source 0
how can i set it up?
