Isaac Sim 4.1.0.
When I use ArticulationAction(API) to simultaneously set the angle and angular velocity of the robotic arm, I found that the angular velocity set by API(robot. get_joint_velocity()) is completely different from that set by ArticulationAction.
How to set the target angle of the robotic arm joint and make the robotic arm joint move at the set target speed.
Thank you for contacting us regarding the issue you’re experiencing with your robotic arm. To help us understand and potentially reproduce the problem, please provide a detailed, step-by-step description of the process, along with any relevant files needed to replicate the issue.
Additionally, please try using Isaac Sim version 4.2.0.
