Description
A problem happened when I tried to install torch2trt with plugins after solving the problem "fatal error: NvInfer.h: No such file or directory
Environment
TensorRT Version: 7.0.0
GPU Type: 2080ti
CUDA Version: 10.0
Operating System + Version: Ubuntu 16.04 LTS
Python Version (if applicable): 3.6
PyTorch Version (if applicable): 1.7.0
Shell output text
torch2trt/plugins/group_norm.cpp: In member function ‘void torch2trt::GroupNormPlugin::deserializeFromString(const string&)’:
torch2trt/plugins/group_norm.cpp:52:24: error: cannot convert ‘std::vector’ to ‘int64_t {aka long int}’ in assignment
num_groups = value.toIntListRef().vec();
torch2trt/plugins/group_norm.cpp:72:17: error: cannot convert ‘std::vector’ to ‘double’ in assignment
eps = value.toDoubleListRef().vec();
torch2trt/plugins/group_norm.cpp: In member function ‘std::string torch2trt::GroupNormPlugin::serializeToString() const’:
torch2trt/plugins/group_norm.cpp:108:70: warning: ‘c10::IValue::IValue(std::vector)’ is deprecated [-Wdeprecated-declarations]
output_archive.write(“input_sizes”, torch::IValue(input_sizes));
In file included from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/core/ivalue.h:636:0,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/core/stack.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/core/ATenDispatch.h:15,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/core/TensorMethods.h:10,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/Tensor.h:12,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/Context.h:4,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/ATen.h:5,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/types.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/data/dataloader_options.h:4,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/data/dataloader/base.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/data/dataloader/stateful.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/data/dataloader.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/data.h:3,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/csrc/api/include/torch/all.h:4,
from /home/hlf/.local/lib/python3.5/site-packages/torch/include/torch/extension.h:4,
from torch2trt/plugins/plugins.cpp:1:
/home/hlf/.local/lib/python3.5/site-packages/torch/include/ATen/core/ivalue_inl.h:616:8: note: declared here
inline IValue::IValue(std::vector<int64_t> v)
In file included from torch2trt/plugins/plugins.cpp:3:0:
torch2trt/plugins/group_norm.cpp:109:72: warning: ‘c10::IValue::IValue(std::vector)’ is deprecated [-Wdeprecated-declarations]
output_archive.write(“output_sizes”, torch::IValue(output_sizes));
error: command ‘x86_64-linux-gnu-gcc’ failed with exit status 1
