In the mosaic mode, when I specify the GPU in the deepstream-test3 (we have two GPUs), the running code will prompt that the device does not support (CUDA 804).
Who can help solve this problem?
Thank you very much!
We do not support or test this platform nor mosaic mode. We recommend trying another solution than DeepStream. You may explore - Instead of tiling all the sources as done in test3 app, demux all the sources and feed it to different sink components and set display window of sources accordingly for all 16 sources. Also we usually recommend using latest version of deepstream.
Thank you for your reply!
If I have two P1000 GPUs, how can I make the monitors connected to these two GPUs display?
For example, we connect 8 monitors on these two cards, and each monitor can display a video stream.
However, the problem is that if the mosaic mode is not used, only the four monitors connected to one card can display normally, while the four monitors on the other card cannot display.
In addition, what is the comment 9#?
You have same two cards, it does not make sense the other four monitors on the other card cannot display. please specify more details.
