Hello everyone,
I’m having a trouble to link an image continuously updated in a callback function (video from UDP) to driveworks. The image is on CPU and I’ve already tried to use the dwImageStreamer as in the following code inside of my callback function:
*(&image->data[0]) = t_ima.data; // image is a dwImageCPU
dwImageStreamer_postCPU(image, m_cpuImas);
dwImageCUDA *cudaYUV = new dwImageCUDA;
dwImageStreamer_receiveCUDA(&cudaYUV, 10000,m_cpuImas);
dwImageFormatConverter_copyConvertCUDA(g_cudaRGBA, cudaYUV, g_yuv2RGBA, (cudaStream_t)0);
dwImageStreamer_postCUDA(g_cudaRGBA, g_image2GL);
dwImageGL *m_frameGlRgba;
dwImageStreamer_receiveGL(&m_frameGlRgba, 30000, g_image2GL);
dwImageCUDA *processed;
if (dwImageStreamer_waitPostedCUDA(&processed, 30000, g_image2GL) !=
DW_SUCCESS ||
processed != g_cudaRGBA) {
std::cerr << "consumer did not gave frame back" << std::endl;
*(g_newFrames[0]) = *cudaYUV;
All the streamer variables were initialized before. There is no error in the compilation, however I got a seg default or sometimes just black image in the GUI. Can anyone have solved this issue? or have some similar code example?
Thank you in advance.
