How to stream rtsp video better?
• Hardware Platform: Jetson Xavier NX
• DeepStream Version:5.0.0
• JetPack Version (valid for Jetson only):4.4
I wish to make the 4k RTSP stream to be more stable that being implemented in deepstream-test5, it seems like sometime when the network not stable it will show the distorted image like below. I know that the RTSP is using the UDP to stream the video, is this problem will be solved by changing streaming using TCP?
It may be similar to this topic:
Encoding problem RTSp stream - #6 by DaneLLL
You may try type=2 or type=4 with setting drop-on-latency=0
And can try to tune some properties:
deepstream4.0 with rtsp of sink makes the picture distortion with high bitrate - #9 by DaneLLL
Hi, @DaneLLL
Thank you for replying! I have know the topics, but I tested with those topic seems like not perfect, I increased the bitrate and followed the topic such as setting MTU-size or force the rtsp to connect as TCP and etc, although it seems like smoothly than before, however I hope to use as surveillance purpose for real time I hope that rtsp stream will not drop frame, does nvidia tested with tcp stream instead of udp stream?
The UDP streaming actually happens inside Xavier NX and is not a public streaming. The RTSP server is constructed by calling
gst_rtsp_media_factory_set_launch (factory, udpsrc_pipeline);
The code is open source in
deepstream-5.0\sources\apps\apps-common\src
May need other users to share experience and you can customize the code to give it a try.
Setting vbv-size in hardware encoder might help. Please take a look at
@DaneLLL Thank you so much about the information, I tested with your advice by changing the vbv-size seems like work fine for my case. I would like to experiment with different vbv-size in order to get smooth rtsp.
