@Amycao ,
This is filter out on some class id to skip that class-id for pushing objects metadata to upstream element(tracker), but my purpose is difference from that,
I have pgie followed by sgie and then tracker, but the tracker see both objects of pgie and sgie, and tackers both objects, but I want to tracks only sgie objects.
@Amycao,
How? If I do this way, So the sgie has’t any objects to inference, right?
The best way is that the tracker should to has same options config file like pgie and sgie, then we set the objects with unique component id for skipping, or the tracker should to has same property of pgie and sgie like this: operate-on-gie-id operate-on-class-ids
