How to turn off auto-capture when gstreamer pipeline runs? only on-demand
Our use case is to capture images/snapshots on demand, which is very similar to nvgstcapture when “j” clicked.
As we go through the sample code and create our own pipeline basically just running
capbin → cap_tee → ienc_q → svc_imgbin → img_bin
with copying the part of trigger_image_capture() and the callback cam_image_captured().
We couldn’t figure out how to start the pipeline and keep it in an idle mode (if that’s the right word). Like in nvgstcapture, only when “j” clicked, there is a frame captured and go through the pipeline.
But in our own application, there are frames going through the pipeline constantly. We’ve checked “mode” for nvtee, and “intent”/“trigger” for nvcamerasrc, but still coudn’t figure out.
Update:
I guess my question is how to turn off the auto-capture after the pipeline runs. Capturing only on-demand.
I edit the title.
Please help. Thanks a lot.
Please refer to
[url]https://devtalk.nvidia.com/default/topic/1043245/jetson-tx2/storing-camera-footage-in-jpeg-files-with-format/post/5292078/#5292078[/url]
Thanks a lot for the reply. Our application is in C.
Are you suggesting we need to check on “num-buffers”?
Hi Michael,
The pipeline is continuous jpeg encoding. I misunderstood your usecase.
So in your application, do you use nvcamerasrc? The element nvcamerasrc implements intent and trigger properties for on-demand jpeg encoding. If you don’t use nvcamerasrc, the function may not work.
Hi Michael,
Please refer to attachment.
# Install
sudo apt-get install libgstreamer1.0-dev
sudo apt-get install libgstreamer-plugins-base1.0-dev
# compile with below command
g++ -Wall -std=c++11  gst_jpg_on_demand.cpp -o test $(pkg-config --cflags --libs gstreamer-app-1.0)
gst_jpg_on_demand.zip (1.61 KB)
Hello Dane,
Yes, we use nvcamerasrc and its properties intent/trigger trying to duplicate what nvgstcapture does when “j” clicked. While nvgstcapture pass a sinlge frame, our pipeline continuously has data. We are trying to figure out how to idle the pipeline. Thanks a lot for the reply.
Thanks for the sample. It captures two images when frame_count = 123/168 in each run.
When it’s not saving the frame to a jpeg, there are still data/frame running in the pipeline which is similar to what our application does.
My question is, is it possbile to idle/freeze the pipeline after “GST_STATE_PLAYING”, during which no data running. Until user sends request, then there is a single frame/buffer passsing through the pipeline and saved to a jpg.
“nvgstcapture” seems to like that, but we couldn’t figure out the trick at this moment.
[quote=“DaneLLL”]
Hi Michael,
Hi Michael,
You can build full nvgstcapture and remove the part not required in your usecase. There are four source pads in nvtee: pre_src, img_src, vid_src, vsnap_src. Looks like vid_src and vsnap_src are not required in your usecase.
Please check attachment.
r28_2_1_nvgstcapture.zip (25 KB)
Thanks a lot.
Hey Michael,
Did you figure out a solution for this? I’m trying to accomplish the same. Thanks!
Check the source code of nvgstcapture-1.0 by Nvidia.
Will do. If you happen to have any modified source/binary you could share it would be appreciated. No worries if you can’t though. Thanks!
I was able to easily add a SIGINT handler for triggering images:
Seems to be working well.
