HI, how to upgrade jetpack 5.1.1 to new jetpack version? The machine is enabled rootfs_ab
Hi user148386,
What’s your current Jetpack version in use?
Do you have NVMe connected on your board? Or you just use internal eMMC as rootfs and rootfs a/b enabled?
Hi, I am using the Jetson AGX Orin. The machine uses NVMe to storage user data , and we use internal eMMC as rootfs and rootfs a/b enabled.
Please help to answer the following 2 questions so that we could know your status.
- Are you using the devkit or custom board?
- What’s your current Jetpack version in use?
It seems you want to perform image-based OTA update for internal eMMC with rootfs a/b enabled.
Please refer to <Linux_for_Tegra>/tools/ota_tools/version_upgrade/Image_based_OTA_Examples.txt for details.
$ sudo ROOTFS_AB=1 ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-agx-orin-devkit R35-3
- I am using the custom board
- Jetpack version is 5.1.1
Ooh, I will try to test it.
My previous method before was to modify /etc/apt/sources.list.d/nvidia-l4t-apt-source.list to upgrade.
Debian based OTA is unavailable for custom carrier board since the customization would not exist there.
Please use image based OTA instead for your custom board.
