How to use 12_camera_v4l2_cuda with Opencv in jetson nano?
HI,
@Andrey1984 @DaneLLL :)
I am using a Logitec Brio camera. I followed the below link to read and access the camera which works fine at 30 fps.
I could run the below only from the terminal.
$ ./camera_v4l2_cuda -d /dev/video0 -s 640x480 -f YUYV -n 30 -c
I want to use this with cv2.videocapture() in Opencv, so that I can integrate with my CNN code.
Kindly help me on how to use ‘camera_v4l2_cuda’ with cv2.
For hooking with OpenCV, we suggest use gstreamer pipeline. Please take a look at
@DaneLLL : Thanks a lot. The Pipeline you provided works like a charm. Interested to understand the technique /method to construct this pipeline. Any document available to understand the pipeline construction ?
We have samples in C in the source code package:
https://developer.nvidia.com/embedded/linux-tegra
L4T Driver Package (BSP) Sources
Document:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0E0LQ0HA
The python samples are based on the C samples.
