Jetson Nano with Logitech Brio
Dear Experts,
When I connected logitech brio on jetson nano, I could stream video only 10 fps @ 4K. Is this limitation of jetsion nano or do I missed something ?
Thanks,
Please share information of running $ v4l2-ctl --list-formats-ext
We have Logitech C930 but don’t have Brio. The information can give us some basic understanding to the camera. Also please share your release version.
A reference link:
https://devtalk.nvidia.com/default/topic/1057681/jetson-tx1/logitech-c930e-on-jetson-tx1-very-slow-and-choppy-video/post/5363417/#5363417
This is the output of running $ v4l2-ctl --list-formats-ext. And the release version is L4T 32.3.1.
I used GUVCViewer and set 60 fps with 4096x2160, MJPG format, streaming fps is only 8.5
Appreciate for your help.
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Index       : 1
Pixel Format: 'MJPG' (compressed)
		Interval: Discrete 0.008s (120.000 fps)
		Interval: Discrete 0.011s (90.000 fps)
		Interval: Discrete 0.017s (60.000 fps)
	Size: Discrete 2560x1440
	Size: Discrete 3840x2160
	Size: Discrete 4096x2160
Index       : 2
Pixel Format: 'NV12'
The optimal performance is to use tegra_multimedia_api. Please check 12_camera_v4l2_cuda sample. MJPEG format is supported.
how to stream with it? in 4K? with logitech brio? so it is uses encoding to an extent when the streaming is not lagging?
 $ cd 12_camera_v4l2_cuda
  $ make
To run
Enter:
  $ ./camera_v4l2_cuda -d /dev/video0 -s 1280x720 -f YUYV -c
The -c option enables CUDA processing.
Or enter:
  $ ./camera_v4l2_cuda -d /dev/video0 -s 640x480 -f YUYV -n 30 -c
https://docs.nvidia.com/jetson/l4t-multimedia/l4t_mm_v4l2_cam_cuda_group.html
Please set -f MJPEG if you would like to run MJPG decoding.
Hi Andrey, I am using the same camera with Jetson Nano. The below command works and thanks for that,
How do I use this with Opencv cv2.videocapture() ?
