Hello!
Is it possible to set the USB camera to video capture MJPG 4096 x 2160 for high resolution / slow frame rate?
If so, how?
If not, how about NV12, 1920 x 1080?
Else, maybe YUYV 1920 x 1080 ?
Camera is Logitech Brio 4K.
Hello!
If so, how?
I don’t have such camera, but assuming your brio is /dev/video1, you may try:
# Boost clocks
sudo jetson_clocks
gst-launch-1.0 v4l2src device=/dev/video1 ! 'image/jpeg, width=4096, height=2160, framerate=5/1, format=MJPG' ! jpegdec ! xvimagesink
# If it doesn't work fine, you may different io modes (see: gst-inspect-1.0 v4l2src) such as:
gst-launch-1.0 v4l2src device=/dev/video1 io-mode=2 ! 'image/jpeg, format=MJPG, width=4096, height=2160, framerate=5/1' ! jpegdec ! xvimagesink
For YUYV 4:2:2, you may try:
gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw, format=YUY2, width=1920, height=1080, framerate=30/1' ! videoconvert ! xvimagesink
For NV12:
gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1' ! videoconvert ! xvimagesink
# If previous command gives bad scaling, you may also try instead:
gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1' ! nvvidconv ! nvegltransform ! nveglglessink
Thanks, @Honey_Patouceul ,
gst-launch-1.0 v4l2src device=/dev/video0 ! 'image/jpeg, width=4096, height=2160, framerate=5/1, format=MJPG' ! jpegdec ! xvimagesink
… worked in command line. How do I now do this within detectNet / detectnet-camera? It always seems to revert to 1280 x 720.
Seems for now it expects NV12 from nvarguscamerasrc for onboard camera, or RGB from USB cam.
You may try to adjust the pipeline string created here for a pipeline providing RGB from your camera MJPG stream.
You may first prototype with gst-launch:
gst-launch-1.0 v4l2src device=/dev/video0 ! 'image/jpeg, width=4096, height=2160, framerate=5/1, format=MJPG' ! jpegdec ! 'video/x-raw,format=RGB' ! videoconvert ! appsink
If this works, you would try to make a pipeline string such as :
v4l2src device=/dev/video0 ! image/jpeg,width=4096,height=2160,framerate=5/1,format=MJPG ! jpegdec ! video/x-raw,format=RGB ! videoconvert ! appsink
You may adjust default camera here to 0 instead of -1 for onboard camera.
Probably @dusty_nv would be able to give better advice.
I found where default width and heights are set:
gstCamera.h … Line 81 and 82:
// Default resolution, unless otherwise specified during Create()
static const uint32_t DefaultWidth = 1280;
static const uint32_t DefaultHeight = 720;
Will test it out.
Seems to work.
static const uint32_t DefaultWidth = 4096;
static const uint32_t DefaultHeight = 2160;
Edited gstCamera.h as above then:
cd jetson-inference/build
cmake ../
make
detectnet-camera
args (3): 0 [./detectnet-camera] 1 [--prototxt=swede_11890/deploy.prototxt] 2 [--model=swede_11890/swede_11890.caffemodel]
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVCAMERA
[gstreamer] gstCamera pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)4096, height=(int)2160, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2
detectnet-camera: successfully initialized video device
width: 4096
height: 2160
depth: 24 (bpp)
detectNet -- loading detection network model from:
-- prototxt swede_11890/deploy.prototxt
-- model swede_11890/swede_11890.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- class_labels NULL
-- THRESHOLD 0.500000
-- batch_size 2
[TRT] TensorRT version 4.0.2
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file swede_11890/swede_11890.caffemodel.2.1.GPU.FP16.engine
[TRT] loading network profile from engine cache... swede_11890/swede_11890.caffemodel.2.1.GPU.FP16.engine
[TRT] device GPU, swede_11890/swede_11890.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 3 bindings
[TRT] swede_11890/swede_11890.caffemodel input binding index: 0
[TRT] swede_11890/swede_11890.caffemodel input dims (b=2 c=3 h=640 w=640) size=9830400
[cuda] cudaAllocMapped 9830400 bytes, CPU 0x101540000 GPU 0x101540000
[TRT] swede_11890/swede_11890.caffemodel output 0 coverage binding index: 1
[TRT] swede_11890/swede_11890.caffemodel output 0 coverage dims (b=2 c=1 h=40 w=40) size=12800
[cuda] cudaAllocMapped 12800 bytes, CPU 0x101ea0000 GPU 0x101ea0000
[TRT] swede_11890/swede_11890.caffemodel output 1 bboxes binding index: 2
[TRT] swede_11890/swede_11890.caffemodel output 1 bboxes dims (b=2 c=4 h=40 w=40) size=51200
[cuda] cudaAllocMapped 51200 bytes, CPU 0x1020a0000 GPU 0x1020a0000
device GPU, swede_11890/swede_11890.caffemodel initialized.
[cuda] cudaAllocMapped 16 bytes, CPU 0x101340200 GPU 0x101340200
detectNet -- model has 1 object classes
detectNet -- maximum bounding boxes: 6400
[cuda] cudaAllocMapped 102400 bytes, CPU 0x1022a0000 GPU 0x1022a0000
[cuda] cudaAllocMapped 25600 bytes, CPU 0x1020ac800 GPU 0x1020ac800
default X screen 0: 1920 x 1080
[OpenGL] glDisplay display window initialized
[OpenGL] creating 4096x2160 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x1024a0000 GPU 0x1024a0000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x101ea3200 GPU 0x101ea3200
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg stream-start ==> pipeline0
detectnet-camera: camera open for streaming
detectnet-camera: failed to capture frame
detectnet-camera: failed to convert from NV12 to RGBA
detectNet::Detect( 0x(nil), 4096, 2160 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/jetson-inference/detectnet-camera/detectnet-camera.cpp:247
[cuda] registered 141557760 byte openGL texture for interop access (4096x2160)
[gstreamer] gstCamera onPreroll
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x10adb0000 GPU 0x10adb0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x10c700000 GPU 0x10c700000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x10e050000 GPU 0x10e050000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x10f9a0000 GPU 0x10f9a0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x1112f0000 GPU 0x1112f0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x112c40000 GPU 0x112c40000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x114590000 GPU 0x114590000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x115ee0000 GPU 0x115ee0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x117830000 GPU 0x117830000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x119180000 GPU 0x119180000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x11aad0000 GPU 0x11aad0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x11c420000 GPU 0x11c420000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x11dd70000 GPU 0x11dd70000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x11f6c0000 GPU 0x11f6c0000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x121010000 GPU 0x121010000
[cuda] cudaAllocMapped 26542080 bytes, CPU 0x122960000 GPU 0x122960000
[cuda] gstreamer camera -- allocated 16 ringbuffers, 26542080 bytes each
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer msg async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] gstreamer camera -- allocated 16 RGBA ringbuffers
[gstreamer] gstreamer msg qos ==> v4l2src0
0 bounding BOXES detected
1 bounding BOXES detected
detected obj 0 class #0 (person) confidence=1.007812
bounding box 0 (1160.750000, -9.228516) (1620.000000, 882.509766) w=459.250000 h=891.738281
detected obj 0 class #0 (person) confidence=0.653809
bounding box 0 (1191.500000, 90.439453) (1576.125000, 853.505859) w=384.625000 h=763.066406
You seem to use a different pipeline, not using MJPG:
Does your brio cam provides 4096x2160 in RGB format ?
Check with
v4l2-ctl -d /dev/video --list-formats-ext
Or check with gst-launch:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! 'video/x-raw, width=(int)4096, height=(int)2160, format=RGB' ! videoconvert ! 'video/x-raw, format=RGB' ! videoconvert ! appsink
If this works, probably v4l2src does the conversion into RGB.
If this doesn’t work you would have to modify the building of the gstreamer pipeline string as suggested in my previous post.
Does not seem to metion RGB:
v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.008s (120.000 fps)
Interval: Discrete 0.011s (90.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 2560x1440
Size: Discrete 3840x2160
Size: Discrete 4096x2160
Index : 2
Pixel Format: 'NV12'
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstAppSink:appsink0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)4096\,\ height\=\(int\)2160\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1"
Killed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
Execution ended after 0:00:01.887157472
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
@Honey_Patouceul detectNet is now working with the Brio, thanks for the pointer to gstCamera. I’m not sure what’s happening in the software, some conversion from MJPG to RGB I think?
Now need to reduce the display size so that it fits on my low res screen again! I’ve created a new thread to address this problem.
Seems the MJPG to RGB conversion is done by V4L, or it may also just resize from a lower resolution…
Last case may have failed because jpegdec is slow if you didn’t boost clocks this time.
Anyway, glad to see it works and you shared.
