USB Webcam Slow, Low Framerate, Delay
I am using Microsoft LifeCam Studio on Jetson Nano (JetPack 4.4), but, found the response is very slow.
I only have around 2 FPS and the capture video have around 3 seconds of delay.
Any solution ?
You may tell how you are accessing your camera for better advice.
From gstreamer with v4l2src ? If yes, you may try option io-mode=2.
I got this result, even I just run video-viewer v4l2:///dev/video0
What gives (assuming this cam is /dev/video0):
sudo apt install v4l-utils
v4l2-ctl -d0 --list-formats-ext
It listed 3 formats, YUYV, MJPG, M420 pixel format
Be sure your USB BW is ok:
lsusb -t
It may be an issue with MJPG format, you may try YUY2 format (raw) :
video-viewer v4l2:///dev/video0 --input-codec=raw
If not working, please share the full output.
It work fine now
Many thanks !!
Hi, sorry for highjacking. I’m having the same issue with 3 brand new USB-2 cams on a Jetson nano. All cams give 30 fps on other devices (whereas I have to admit, this is not a constant achievement. Sometimes also these ominous 11 fps have been seen…)
Admittedly these are inexpensive cams (about 24 € each).
I have already made all tests suggested so far, but I cannot achieve 30fps.
neil@jetson:~$ lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/5p, 480M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
        |__ Port 1: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
        |__ Port 2: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
        |__ Port 2: Dev 4, If 3, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
        |__ Port 3: Dev 5, If 3, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 3: Dev 5, If 1, Class=Video, Driver=uvcvideo, 480M
        |__ Port 3: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 3: Dev 5, If 0, Class=Video, Driver=uvcvideo, 480M
        |__ Port 4: Dev 6, If 3, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 4: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M
        |__ Port 4: Dev 6, If 2, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 4: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M
neil@jetson:~$ v4l2-ctl -d0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'MJPG' (compressed)
		Size: Discrete 1920x1080
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.040s (25.000 fps)
			Interval: Discrete 0.050s (20.000 fps)
			Interval: Discrete 0.067s (15.000 fps)
			Interval: Discrete 0.100s (10.000 fps)
			Interval: Discrete 0.200s (5.000 fps)
	Index       : 1
	Pixel Format: 'YUYV'
neil@jetson:~$
video-viewer v4l2:///dev/video0 --input-codec=raw with or without --input-codec shows not more than 11 fps…
