How to use capture NvSciBufObj in 2d
Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
SDK Manager Version
other
Host Machine Version
other
Issue Description
目前在研究Nv 2d接口的时候遇到了问题,使用官方demo自己创建NvSciBufObj,并使用NvMedia2DFillNvSciBufAttrList接口填充2d属性,这个buffer是可以送进2d接口的.但是如果直接使用摄像头输出的buffer(通过nvsipl::INvSIPLClient::INvSIPLNvMBuffer->GetNvSciBufImage())获取到的,结果在调用NvMedia2DRegisterNvSciBufObj注册时返回错误码1,我应该如何配置摄像头模块,使其产生的buffer可以直接给2d接口使用。
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @qiuwen ,
could you check syslog to get more insights on the encountered error. Also, can you share the code? As I understand, you want to perform NVSIPL-> 2D in pipeline.
Dear @qiuwen ,
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Could you please provide any update? Can we close the topic?
