Please provide the following info:
Hardware Platform: DRIVE AGX Xavier™
Software Version: DRIVE Software 10
Host Machine Version: Ubuntu 18.04
SDK Manager Version: 5.1.15.0
I am trying to setup streaming from SIPL to a consumer through Nvsci.
I am using the Nvidia sample “nvsipl_camera” as a guideline but am experiencing some issues when setting up the output of the ICP and ISP using RegisterImageGroups() and RegisterImages() API calls.
The stream is being setup with 3 packets. The producer attr list is created via GetImageAttributes() API call with ISP output type and the the consumers attr list is created as a NvSciBufType_Image with cpu access required and read only permissions.
The stream is setup and all the element status and packet status events are received by the pool for the 3 packets (each with 1 element).
I am then trying to register the ISP and ICP images using RegisterImageGroups() and RegisterImages() API calls and getting the following error.
: CNvMBufferPool.hpp: 181: GetSciBuffer: Failed to get free buffer from pool
: CNvMBufferPool.hpp: 101: Init: GetSciBuffer failed
: CNvMSensorPipeline.cpp: 214: RegisterImages: ISP[0] buffer pool initialize failed
: CNvMCamera.cpp: 599: RegisterImages: Pipeline register images failed for pipeline:0
How can I debug what exactly is causing this error?
