Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
I want to get an image of yuv444_8b or RGBA_8b using sipl_camera sample.
I changed the AllocateAndRegisterBuffers() of CNvSIPLMaster.hpp as follows.
if (isp0Enabled) {
// Get attributes
NvSIPLImageAttr attr;
status = m_pCamera->GetImageAttributes(pip, INvSIPLClient::ConsumerDesc::OutputType::ISP0, attr);
if (status != NVSIPL_STATUS_OK) {
LOG_ERR("GetImageAttributes failed\n");
return status;
NVM_SURF_FMT_DEFINE_ATTR(surfFormatAttrs);
NVM_SURF_FMT_SET_ATTR_YUV (surfFormatAttrs, YUV, 444, SEMI_PLANAR, UINT, 8, BL);
attr.surfaceType =NvMediaSurfaceFormatGetType(surfFormatAttrs, NVM_SURF_FMT_ATTR_MAX);
std::vector<NvMediaImage*> images;
status = AllocateImages(pDevice, attr.surfaceType, attr.surfaceAllocAttr, images);
LOG_ERR("AllocateImages failed\n");
return status;
printf("resigter image start \n");
status = m_pCamera->RegisterImages(pip, INvSIPLClient::ConsumerDesc::OutputType::ISP0, images);
printf("resigter image end \n");
LOG_WARN("RegisterImageGroups failed\n");
DeleteImages(images);
return status;
m_imagesList.push_back(images);
But when I run it, I get an error in the RegisterAutoControl().
How can I change the output of ISP to something like YUV444?
./nvsipl_camera -c “IMX390_RGGB_CPHY_x4” -m “0x0001 0x0000 0x0000 0x0000” -d 0 -w 1 --disableISP1Output -f “test.yuv”
nvsipl_camera: Opened NITO file for module “IMX390_RGGB”
[SiplControlIspCheckImageInfo:210] [SiplControlIspCheckImageInfo:210] Bad input parameter : Out SURF
[SiplControlIspInitRangeCheck:1439] [SiplControlIspInitRangeCheck:1439] Bad input parameter
[SiplControlIspInit:68] [SiplControlIspInit:68] Bad init parameter
Main: CNvMISPBlock.cpp: 216: RegisterAutoControlPlugin: createSiplControlIsp: Failed to create Sipl Control ISP
Main: CNvMSensorPipeline.cpp: 263: RegisterAutoControlPlugin: ISP block register auto control plugin failed
Main: CNvMCamera.cpp: 342: RegisterAutoControlPlugin: RegisterAutoControlPlugin type:0 failed for pipeline:0
nvsipl_camera: ERROR: SetSiplControl(NV) failed for ISP output of sensor:0
