I’m having some issues when I run the NVM_SURF_FMT_SET_ATTR_RGBA() macro in the nvsipl_camera example code to modify the surface type for ISP1/ISP0. I would like to change the output to RGBA UINT8, but I am getting errors when I run the RegisterAutoControl() method when using the parameters of RGBA, UINT, 8, PL.
I found a similar post in the forums, found here, but the user wanted YUVX, but I would like to get RGB output.
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Dear @jason.wu2,
Just to confirm, you want the output surface of ISP to be RGBA?
Dear @jason.wu2,
We do not support RGBA UINT8 from ISP. You need to use VIC for YUV to RGBA conversion.
To @SivaRamaKrishnaNV,
Thanks for the update. Can I get some more information about VIC, I’ll close the topic when you get back to me. Also, we are trying to convert RGBA Float16 to RGBA UINT8.
Does the ISP happen to support an RGB uint8 or an RGB 16-bit float output instead of RGBA?
Dear @michael.honey,
No.
Hey @SivaRamaKrishnaNV , I’ve looked into the documentation that you linked me, and I’m not sure if it is relevant to what I’m trying to do. I don’t wish to do a blit operation, just a conversion.
Also, I wasn’t able to find much information regarding the VIC or how to use it.
Dear @jason.wu2,
Image 2D can do YUV-> RGBA conversion. Please set the src/dst surf and other parameters accorndingly.
