Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Thanks, I’ll try that.
I would like to confirm that whether the conversion from RAW12 to RGB, which is demosaicing, is supported in ISP with any existing xxx.nito config.
I have tried different combinations in NVM_SURF_FMT_SET_ATTR_RGBA()
then put the NvMediaSurfFormatAttr result to NvMediaSurfaceFormatGetType to get the surface format flag number.
None of the configuration works.
I got the same console output from all the configurations I’ve tried:
sample_m: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 705: Deinit: Deinit() call in wrong state
sample_m: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:0
sample_m: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 49: ~CNvMCamera: CNvMCamera object fails to deinit
