Hi @d.baykeda
Please refer to Is there a way to let ISP output RGB?. But if you encounter some issue with a failure rate (as mentioned in ISP fails depending on Log output level), the fix won’t be available because of no more releases for DRIVE AGX Xaiver. FYI.
