Script for SF3325, nvmimg_cc
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Hello. I am new to the Xavier platform. I was wondering if the script example provided on https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/NvMedia/nvmedia_nvmimg_cc.html#
would work for SF3325, the one that is included in the Xavier Hardware Kit. If not, any idea/help of getting a script that would work for it? Doesnt matter if it is already created somewhere or i would have to create it myself
NvMedia ICP APIs are deprecated in DRIVE OS 5.2.0. Instead, we recommend using SIPL sample applications such as the SIPL Camera (nvsipl_camera).
I see. My main intentions were to somehow get the pointer that contains the pixels of a frame (preferably in raw format) so that i could do image processing on them, however i have met some difficulties like i ve written a frame from m_rawImageBufs (in CComposite.cpp) to pgm format but got static image. Then tried out to save the output using the FileWriter class but i am unable to play the video with any other media player, so i wanted to see any other possibility to get my hands on the raw data (i ve realized there is no source code for this app, after i ve posted this topic)
Please refer to the ‘-f’ command line switch mentioned in the ‘nvsipl_camera’ document section and see if it helps with your use cases.
Also, the source code is under /drive/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera/ within the docker container.
That is where i first started, but got no luck so far, but have to admit, I’m new to all this so please, bear with me. However, i would like to ask about the Surface structs defined in nvmedia_image.h (NVIDIA DRIVE OS Linux SDK API Reference: NvMediaImageSurface Struct Reference | NVIDIA Docs) (NVIDIA DRIVE OS Linux SDK API Reference: NvMediaImageSurfaceMap Struct Reference | NVIDIA Docs). If you could explain or point me to a guide/documentation that tells me how to interpret all those variables and also, if the variables mapping and metadata do contain the image pixels
I recommend cross-referencing the implementation in CFileWriter.hpp of the nvsipl_camera sample application. This file and others may provide insights into how these structs are utilized.
Thanks. Appearently, i was looking in the wrong direction. Since i wanted to access a pointer that has the image in grayscale, i realized that rather using the raw format, i should have worked with the yuv format. By accessing the surface of index 0, i was able to access the image in grayscale
