Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
We are using IMX390.
I want to do raw to rgba conversion from raw data using SIPL simulator.
Therefore, since the implementation is different from the actual sample, the code of the construction part of the pipeline is shared instead of the command.
Please let me know if there are any missing settings.
// INvSIPLQuery
auto query = INvSIPLQuery::GetInstance();
if (query == nullptr) {
DLOG_DEBUG(0, "INvSIPLQuery::GetInstance() failed.");
return kFailure;
// Parse database
auto status = query->ParseDatabase();
if (status != NVSIPL_STATUS_OK) {
DLOG_DEBUG(0, ("INvSIPLQuery::ParseDatabase() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
// Set verbosity level
INvSIPLQueryTrace::GetInstance()->SetLevel(INvSIPLQueryTrace::TraceLevel::LevelCritical);
INvSIPLTrace::GetInstance()->SetLevel(INvSIPLTrace::TraceLevel::LevelWarning);
CLogger::GetInstance().SetLogLevel(CLogger::LogLevel::LEVEL_WARNING);
// INvSIPLTrace::GetInstance()->SetLevel(INvSIPLTrace::TraceLevel::LevelDebug);
// CLogger::GetInstance().SetLogLevel(CLogger::LogLevel::LEVEL_INFORMATION);
SigSetup();
// Get PlatformCfg
PlatformCfg platform_cfg;
status = query->GetPlatformCfg("IMX390_RGGB_CPHY_x4", platform_cfg);
DLOG_DEBUG(0, ("INvSIPLQuery::GetPlatformCfg() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
// Set SIPL mask
status = query->ApplyMask(platform_cfg, { 0, 0, 1, 0});
DLOG_DEBUG(0, ("INvSIPLQuery::ApplyMask() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
if (platform_cfg.numDeviceBlocks != 1) {
DLOG_DEBUG(0, "Only one device block is supported in simulator mode. Please correct mask.");
return kFailure;
if (platform_cfg.deviceBlockList[0].numCameraModules != 1) {
DLOG_DEBUG(0, "Only one camera module is supported in simulator mode. Please correct mask.");
return kFailure;
platform_cfg.deviceBlockList[0].isSimulatorModeEnabled = true;
sipl_inputter_.reset(new SIPLDataInputter());
const auto& vcinfo = platform_cfg.deviceBlockList[0].cameraModuleInfoList[0].sensorInfo.vcInfo;
status = sipl_inputter_->Init(vcinfo, &inputter_quit_);
DLOG_DEBUG(0, ("SIPLDataInputter::Init() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
sipl_notify_handler_.reset(new CPipelineNotificationHandler());
sipl_master_.reset(new CNvSIPLMaster());
NvSciBufModule buf_module = nullptr;
NvSciSyncModule sync_module = nullptr;
status = sipl_master_->Setup(&platform_cfg, &buf_module, &sync_module);
DLOG_DEBUG(0, ("CNvSIPLMaster::Setup() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
sipl_consumer_.reset(new CNvSIPLConsumer());
status = sipl_consumer_->Init();
DLOG_DEBUG(0, ("CNvSIPLConsumer::Init() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
INvSIPLClient::ConsumerDesc client;
client.eOutputType = INvSIPLClient::ConsumerDesc::OutputType::ISP0;
client.callback = sipl_consumer_.get();
NvSIPLPipelineCfg pipeline_cfg;
pipeline_cfg.clients.push_back(client);
pipeline_cfg.notifier = sipl_notify_handler_.get();
pipeline_cfg.imageGroupWriter = sipl_inputter_.get();
uint32_t sensor_id = platform_cfg.deviceBlockList[0].cameraModuleInfoList[0].sensorInfo.id;
status = sipl_master_->SetPipelineConfig(sensor_id, pipeline_cfg);
DLOG_DEBUG(0, ("CNvSIPLMaster::SetPipelineConfig() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
status = sipl_master_->Init();
DLOG_DEBUG(0, ("CNvSIPLMaster::Init() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
status = sipl_master_->AllocateAndRegisterBuffers(sensor_id, true, false);
DLOG_DEBUG(0, ("CNvSIPLMaster::AllocateAndRegisterBuffers() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
std::string module_name = platform_cfg.deviceBlockList[0].cameraModuleInfoList[0].name;
std::vector<std::uint8_t> blob;
status = LoadNITOFile("/opt/nvidia/nvmedia/nit/", module_name, blob);
DLOG_DEBUG(0, ("LoadNITOFile() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
status = sipl_master_->RegisterAutoControl(sensor_id, NV_PLUGIN, nullptr, blob);
DLOG_DEBUG(0, ("CNvSIPLMaster::RegisterAutoControl() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
auto status = sipl_master_->Start();
DLOG_DEBUG(0, ("CNvSIPLMaster::Start() failed. status = " + logger_.GetSIPLStatusMsg(status)).c_str());
return kFailure;
Dear @N.Miya,
When I set the Log Level of INvSIPLTrace to the Info level, it works normally
Does that mean you could get RGBA without any issue in this case and failed to get only when set to Warning? Or it is different issue than the original query?
I changed the code for below and confirmed that NVM_SURF_ATTR_COLOR_STD_TYPE was set as intended.
However, the situation remains the same and I get an ISP error at the Warning level.
NVM_SURF_FMT_DEFINE_ATTR(surfFormatAttrs);
NVM_SURF_FMT_SET_ATTR_RGBA (surfFormatAttrs, RGBA, UINT, 8, PL);
attr.surfaceType =NvMediaSurfaceFormatGetType(surfFormatAttrs, NVM_SURF_FMT_ATTR_MAX);
for (std::vector<int>::size_type i = 0U; i < attr.surfaceAllocAttr.size(); i++) {
if (attr.surfaceAllocAttr[i].type == NVM_SURF_ATTR_COLOR_STD_TYPE) {
attr.surfaceAllocAttr[i].value = NVM_SURF_ATTR_COLOR_STD_SRGB;
cout << "attr.surfaceAllocAttr i = " << i << "\n";
break;
Console output
attr.surfaceAllocAttr i = 3
[SiplControlSatCscProductCheck:1525] [SiplControlSatCscProductCheck:1525] Bad input parameter
[SiplControlIspRangeCheck:1600] [SiplControlIspRangeCheck:1600] Bad input parameter
[SiplControlIspProcess:614] [SiplControlIspProcess:614] Bad input parameter
NOTIF_INFO_ICP_PROCESSING_DONE. Pipeline: 8
SIPL_ICP_ISP_8: CNvMISPBlock.cpp: 503: ProgramISP: NvSIPLCtrlProcess failed. status:127
SIPL_ICP_ISP_8: CNvMISPBlock.cpp: 382: ProcessISP: ProgramISP failed
SIPL_ICP_ISP_8: CNvMSensorPipeline.cpp: 735: DoISPProcessing: ISP block process isp failed
NOTIF_ERROR_ISP_PROCESSING_FAILURE. Pipeline: 8
I will attach the logs for 3 times including before the occurrence.
nvidia@tegra-ubuntu:/ota/pkg_data/work$ ./nvsipl_camera -c "IMX390RGGBE3_200FOV_RGGB_CPHY_x4" -m "0x0001 0x0000 0x0000 0x0000" -i "imx390.raw" --disableISP1Output -v 1
nvsipl_camera: Opened NITO file for module "IMX390RGGBE3_200FOV_RGGB"
Enter 'les' followed by sensor ID to enable LED
Enter 'lds' followed by sensor ID to disable LED
Enter 'q' to quit the application
q
SUCCESS
q
nvsipl_camera: ERROR: imageSize(4735456) does not match expected surface size(0)
SIPL_ICP_ISP_0: CNvMSensorPipeline.cpp: 674: GetFeederBuffer: FillRawBuffer failed
nvsipl_camera: ERROR: Pipeline: 0, NOTIF_ERROR_INTERNAL_FAILURE
nvsipl_camera: ERROR: Pipeline failure
SIPL_ICP_ISP_0: CNvMISPBlock.cpp: 503: ProgramISP: NvSIPLCtrlProcess failed. status:127
SIPL_ICP_ISP_0: CNvMISPBlock.cpp: 382: ProcessISP: ProgramISP failed
SIPL_ICP_ISP_0: CNvMSensorPipeline.cpp: 735: DoISPProcessing: ISP block process isp failed
nvsipl_camera: ERROR: Pipeline: 0, NOTIF_ERROR_ISP_PROCESSING_FAILURE
The sample is less reproducible, but when incorporated into our application, it is more reproducible.
When incorporated into our program, it occurs every time at the Warning level.
We also want to identify the cause, but it is difficult because there is only information on the Bad input parameter as Log.
I think there is a problem within SiplControlSatCscProductCheck. What are the conditions under which the Bad input parameter is output?
