This error message is printed out when calling SetPlatformCfg()
The RAW file for input is a sample file comes from our camera dev team with RAW8 format
I did not run nvsipl_camera, erros are from sample code I wrote (modified from nvsipl_sample)
I used “SF3325_DPHY_x4” configuration, it comes from the result of NvSIPLQuery. I set the mask to “0x0001 0x0000 0x0000 0x0000” and loaded “/opt/nvidia/nvmedia/nit/sf3325.nito”.
Here is the main.cpp of my sample code
// Standard header files
#include <iostream>
#include <memory>
#include <thread>
#include <mutex>
// SIPL header files
#include "NvSIPLCommon.hpp"
#include "NvSIPLCamera.hpp"
#include "NvSIPLClient.hpp"
#include "NvSIPLPipelineMgr.hpp"
#include "NvSIPLQuery.hpp" // Query
// Sample application header files
#include "CUtils.hpp"
#include "CImageManager.hpp"
#include "QueueHandlers.hpp"
#include "DummyFrameLoader.hpp"
// Platfom configuration header files
#include "platform/common.hpp"
#include "platform/sf3324.hpp"
#include "platform/imx390_c.hpp"
#include "platform/ar0820_b.hpp"
#include "platform/ov2311_c.hpp"
using namespace nvsipl;
* Control information for a single queue.
* Only one of @c imageQueueHandler and @c eventQueueHandler will be active,
* depending on the type of queue being monitored.
struct ThreadData: public FrameCompleteQueueHandler::ICallback,
public NotificationQueueHandler::ICallback
std::string threadName;
FrameCompleteQueueHandler imageQueueHandler;
NotificationQueueHandler eventQueueHandler;
std::mutex *printMutex;
* Process events from the notification queue (if applicable).
void process(const NvSIPLPipelineNotifier::NotificationData& event)
const char *eventName = nullptr;
const SIPLStatus status = GetEventName(event, eventName);
if ((status != NVSIPL_STATUS_OK) || (eventName == nullptr)) {
LOG_ERR("Failed to get event name\n");
} else {
printMutex->lock();
std::cout << threadName << ": " << eventName << std::endl;
printMutex->unlock();
* Process completed images (if applicable).
void process(INvSIPLClient::INvSIPLBuffer* const & pBuffer)
INvSIPLClient::INvSIPLNvMBuffer *pNvMBuffer =
static_cast<INvSIPLClient::INvSIPLNvMBuffer *>(pBuffer);
if (pNvMBuffer == nullptr) {
LOG_ERR("Invalid buffer\n");
} else {
INvSIPLClient::ImageMetaData metadata = pNvMBuffer->GetImageData();
if (!metadata.frameSeqNumInfo.frameSeqNumValid) {
LOG_ERR("Invalid frame sequence number\n");
} else {
printMutex->lock();
std::cout << threadName << ": " \
<< metadata.frameSeqNumInfo.frameSequenceNumber << std::endl;
const SIPLStatus status = pNvMBuffer->Release();
if (status != NVSIPL_STATUS_OK) {
LOG_ERR("Buffer release failed\n");
enum ThreadIndex {
THREAD_INDEX_ICP = 0U,
THREAD_INDEX_ISP0,
THREAD_INDEX_ISP1,
THREAD_INDEX_EVENT,
THREAD_INDEX_COUNT
static SIPLStatus SiplMain(int argc, char *argv[])
SIPLStatus status = NVSIPL_STATUS_OK;
auto pQuery = nvsipl::INvSIPLQuery::GetInstance();
status = pQuery->ParseDatabase();
if (status != nvsipl::NVSIPL_STATUS_OK ) {
printf("status not ok\n");
return status;
PlatformCfg platformCfg;
pQuery->GetPlatformCfg("SF3325_DPHY_x4", platformCfg);
std::vector<uint32_t> vMasks {{
0x0001, 0x0000, 0x0000, 0x0000
pQuery->ApplyMask(platformCfg, vMasks);
platformCfg.deviceBlockList[0].isSimulatorModeEnabled = true;
auto& vcinfo = platformCfg.deviceBlockList[0].cameraModuleInfoList[0].sensorInfo.vcInfo;
vcinfo.inputFormat = NVMEDIA_IMAGE_CAPTURE_INPUT_FORMAT_TYPE_RAW8;
vcinfo.resolution.height = 1152;
vcinfo.resolution.width = 2048;
vcinfo.embeddedBottomLines = 0;
vcinfo.embeddedTopLines = 0;
std::unique_ptr<DummyFrameLoader> fileReader(new DummyFrameLoader());
fileReader->Init("pg-2k.raw", vcinfo);
NvSIPLPipelineConfiguration pipelineCfg = {
.captureOutputRequested = true,
.isp0OutputRequested = true,
.isp1OutputRequested = false
pipelineCfg.imageGroupWriter = fileReader.get();
NvSIPLPipelineQueues queues;
CImageManager imageManager;
std::vector<uint8_t> blob;
bool defaultNitoLoaded = true;
std::mutex threadPrintMutex;
ThreadData threadDataStructs[THREAD_INDEX_COUNT];
bool quit = false;
bool skipNito = false;
std::unique_ptr<INvSIPLCamera> siplCamera = INvSIPLCamera::GetInstance();
CHK_PTR_AND_RETURN(siplCamera, "INvSIPLCamera::GetInstance()");
status = siplCamera->SetPlatformCfg(&platformCfg);
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::SetPlatformCfg()");
status = siplCamera->SetPipelineCfg(SIPL_PIPELINE_ID, pipelineCfg, queues);
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::SetPipelineCfg()");
status = siplCamera->Init();
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::Init()");
status = imageManager.Init(siplCamera.get(), SIPL_PIPELINE_ID, pipelineCfg);
CHK_STATUS_AND_RETURN(status, "CImageManager::Init()");
status = LoadNitoFile("/opt/nvidia/nvmedia/nit/", "sf3325", blob, defaultNitoLoaded);
CHK_STATUS_AND_RETURN(status, "LoadNitoFile()");
if (defaultNitoLoaded) {
LOG_ERR("Module-specific NITO file not found\n");
return NVSIPL_STATUS_NOT_SUPPORTED;
status = siplCamera->RegisterAutoControlPlugin(SIPL_PIPELINE_ID, NV_PLUGIN, nullptr, blob);
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::RegisterAutoControlPlugin()");
for (uint32_t i = 0U; i < THREAD_INDEX_COUNT; i++) {
threadDataStructs[i].printMutex = &threadPrintMutex;
switch (i) {
case THREAD_INDEX_ICP:
threadDataStructs[i].threadName = "ICP";
threadDataStructs[i].imageQueueHandler.Start(queues.captureCompletionQueue,
&threadDataStructs[i],
IMAGE_QUEUE_TIMEOUT_US);
break;
case THREAD_INDEX_ISP0:
threadDataStructs[i].threadName = "ISP0";
threadDataStructs[i].imageQueueHandler.Start(queues.isp0CompletionQueue,
break;
case THREAD_INDEX_ISP1:
threadDataStructs[i].threadName = "ISP1";
threadDataStructs[i].imageQueueHandler.Start(queues.isp1CompletionQueue,
break;
case THREAD_INDEX_EVENT:
threadDataStructs[i].threadName = "Event";
threadDataStructs[i].eventQueueHandler.Start(queues.notificationQueue,
EVENT_QUEUE_TIMEOUT_US);
break;
default:
LOG_ERR("Unexpected thread index\n");
return NVSIPL_STATUS_ERROR;
status = siplCamera->Start();
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::Start()");
// Wait for the user's quit command
while (!quit) {
std::cout << "Enter 'q' to quit the application\n-\n";
char line[INPUT_LINE_READ_SIZE];
std::cin.getline(line, INPUT_LINE_READ_SIZE);
if (line[0] == 'q') {
quit = true;
status = siplCamera->Stop();
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::Stop()");
status = siplCamera->Deinit();
CHK_STATUS_AND_RETURN(status, "INvSIPLCamera::Deinit()");
if (threadDataStructs[i].imageQueueHandler.IsRunning()) {
threadDataStructs[i].imageQueueHandler.Stop();
if (threadDataStructs[i].eventQueueHandler.IsRunning()) {
threadDataStructs[i].eventQueueHandler.Stop();
std::cout << "SUCCESS!" << std::endl;
return status;
int main(int argc, char *argv[])
SIPLStatus status = SiplMain(argc, argv);
return static_cast<int>(status);
Here is the error msg after running it:
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/SensorIF/CNvMSensor.cpp 189
Module_id 30 Severity 2 : Unknown input format 6
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/SensorIF/CNvMSensor.cpp 62
Module_id 30 Severity 2 : CNvMSensor::SetConfig failed with SIPL error 1
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/ar0231/CNvMMAX96712_96705_AR0231.cpp 42
Module_id 30 Severity 2 : AR0231RCCB: GetAR0231RccbConfigSet failed with NvMedia error 7
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.cpp 404
Module_id 30 Severity 2 : MAX96712: Sensor SetConfig failed with SIPL error 1
Module_id 30 Severity 2 : src/devblk/common/ddi/ModuleIF/CNvMCameraModule.cpp 22
Module_id 30 Severity 2 : CNvMCameraModule::SetConfig failed with SIPL error 1
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 226
Module_id 30 Severity 2 : Module SetConfig failed with SIPL error 1
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 93
Module_id 30 Severity 2 : SetConfig failed for device block on port 0x000002
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 3623
Module_id 30 Severity 2 : MAX96712: Null handle passed to MAX96712SetDefaults
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/CNvMMax96712.cpp 237
Module_id 30 Severity 2 : MAX96712: CDI_CONFIG_MAX96712_DISABLE_REPLICATION failed with NvMedia error 1
Module_id 30 Severity 2 : src/devblk/common/ddi/CNvMDevice.cpp 131
Module_id 30 Severity 2 : Driver failed Deinit() call 1
sample_m: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 74: SetPlatformCfg: DeviceBlock manager set config failed
nvsipl_sample: ERROR: INvSIPLCamera::SetPlatformCfg() failed, status: 1
