Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
[*] DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
[*] native Ubuntu 18.04
other
We found Image 2D engine only support below surface component which doesn’t include RGB items.
So if we want to yuv422p to RGB converting, with the help of Image 2D we can convert from yuv422p to RGBA stream. About the rest of converting from RGBA to RGB, except software code method(low performance, cpu costing and time consuming), is there any hardware engine we can apply?
Is there any plan to image 2D support RGB as supported component?
Preformatted textSource surface component order:
1: NVM_SURF_ATTR_COMPONENT_ORDER_LUMA
2: NVM_SURF_ATTR_COMPONENT_ORDER_YUV
3: NVM_SURF_ATTR_COMPONENT_ORDER_YVU
4: NVM_SURF_ATTR_COMPONENT_ORDER_YUYV
5: NVM_SURF_ATTR_COMPONENT_ORDER_YVYU
6: NVM_SURF_ATTR_COMPONENT_ORDER_VYUY
10: NVM_SURF_ATTR_COMPONENT_ORDER_VUYX
18: NVM_SURF_ATTR_COMPONENT_ORDER_RGBA
20: NVM_SURF_ATTR_COMPONENT_ORDER_BGRA
